Hi guys,
I've done some research on here, but have yet to find a definitive answer. Some similar questions have been asked here:
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2845029
and here:
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2909600
Hopefully, the specificity of my question allows for a new thread...
I've recently purchased a 2008 VW GTI with a 2.0 FSI Turbo motor @62k miles. I have decided to use Liqui Moly exclusively after doing a lot of research, and my previous experience with my Audi. Unfortunately, I have been unable to determine the optimal oil to use.
I will be using the "Liqui Moly 2037 Pro-Line Engine Flush" before my 1st oil change, and the "Liqui Moly (20002) Cera Tec Friction Modifier" in my 1st oil change, then as needed. I drive approximately 75miles a day and will be upgrading the car to approx 350hp from the 200hp stock motor. I have narrowed it down to 3 types of oil, but am stuck on the decision. Choices are:
Liqui Moly (2332) Leichtlauf High Tech 5W-40
Liqui Moly (3701) Top Tec 4100 5W-40
Liqui Moly (2041) Synthoil Premium 5W-40
I know they are all "good oils" and meet my VW 502.00 spec. I probably couldn't go wrong using any of them, but which one is best for a modified car, driven roughly, daily?
and here:
