Hi all:
My new Corolla has such a low profile I need to use my car ramps for oil changes. I know that car jacks are recommended when using a floor jack, but is it also a good precaution when using car ramps? I have a very old set of Rhino ramps and have always been a bit nervous that they are made out of plastic. I've never really used jack stands. Once the car is up on the ramp, can they be adjusted to the exact height at which the car is raised? The ones I've used in the past only had set levels adjusted by inserting pins into the proper holes. If I get a good set of steel car ramps, should I still use jack stands? Thanks
