Originally Posted By: mr_blackstock
I was trying to put forward the idea that people who require more protection for their engine, may want more than the standard formula that a company provides.
Then they should use a more robust, properly formulated, lubricant. Dropping in "Wizards in a can" has more of a likelihood of buggering up the balanced product than it does improving it.
Do you think drag racers chuck in the same oil they use in their Honda Civic, Shell 10W-30?
Yes, plenty of them do use plain-Jane conventional 10w-30 actually. Drag racing isn't particularly hard on oil as oil temperature doesn't get very high in 1,320ft. Road racing is much harder on oil.
Why would you suspect that a product being sold by a large oil company be “lesser formulated” than others?
It isn't a suspicion, certain OEM specifications/approvals are much harder to meet than others resulting in a more robust product. Now whether the additional capability of the lubricant is necessary for a specific application, well that's another question all together.
As I will not be continuing to answer idiots who cannot actually read a post without re-interpreting or incorrectly paraphrasing what I have said just so they can bring up another argument they feel they can win even if it has little to do with the original discussion.
Calling people idiots doesn't further your points or make them more clear. Getting frustrated because you feel what you've attempted to convey is being misconstrued doesn't either. If your points are not being properly interpreted then make an attempt to improve your articulation so that it is more clear.
If you do not think additives are worth any use, why do you enter a forum where people positively discuss additives and their uses and try to gain some knowledge? Do you think you are offering any constructive advice by ear bashing people with the same old tired phrases “if it was good, the big companies would use it”, “snake oil is for stupid people”, “if you hate your car, put [censored] in it called snake oil”, “I don’t have to know anything about it to know it’s rubbish” Or do you think you are offering anything new by re-quoting company advertising, and selling it back to us as “fact”?
Or maybe you are the type of people who get off by telling everyone else they are wrong?
Because people join this board to LEARN. Just because the additive section exists doesn't mean it needs to be all Unicorns and Rainbows. New members may be inclined to believe others who are pandering a product that consists of heavy Group I bright stock and tackifier as "beneficial" where there is no tangible evidence to support that it is. Anecdotes that their vehicle didn't blow up are not proof. Listening to these anecdotes also doesn't result in one gaining knowledge, as knowledge is based on fact.
New members deserve to see both sides of these arguments and make an informed decision based on that. This means that they are entitled to hear both the glowing reviews from the pro-additive advocates as well as the potential condemnation of these same products from a more analytical and less cheerleading-oriented perspective. Perhaps one you would call pessimistic and demands proof of benefit.
These discussions, and that is what they are, are a good thing, nobody is required to believe you, me, Shannow, Garak....etc but instead are able to see all that is being debated and take away their own conclusion from the exchange. That is, ideally, how these forums work
