Sparking discussion - excellent article
by JLTD
06/22/18 09:23 PM
Ethylene Glycol Long Life Coolant for KUBOTA
by pburchett
06/22/18 09:11 PM
Mobil 1 5W-30, 6,200 mi, 2017 2.3 EB Explorer
by Whimsey
06/22/18 08:48 PM
Chevron 10w-40, 97 Nissan Maxima, 3000 miles
by OilGeek91
06/22/18 08:36 PM
Old green antifreeze in garage storage is gelling
by JLawrence08648
06/22/18 08:32 PM
VWs at Pick n Pull
by Eric Smith
06/22/18 08:17 PM
Rotella CK-4 destroys the flat tappet
by Gokhan
06/22/18 08:12 PM
Breaking in new short block
by Bub
06/22/18 07:00 PM
Should I buy a mill or a drill press?
by Vern_in_IL
06/22/18 06:32 PM
Weber Q300 Grill Parts Help
by gathermewool
06/22/18 05:24 PM
I Had To Tell Somebody- Banquet
by Zee09
06/22/18 05:13 PM
Xfinity mobile cell service
by jay929
06/22/18 04:37 PM
Fuse "failure"
by dlundblad
06/22/18 04:32 PM
Do you Bluetooth your phone and car?
by ZZman
06/22/18 04:20 PM
Hastings air filters
by Spitter
06/22/18 04:18 PM
2011 Town and Country remote started itself.
by mrsilv04
06/22/18 04:06 PM
Vaughan Hammer and Superbar $10 Sam's
by hatt
06/22/18 04:03 PM
Denso Oil filter - outsourced / quality changed
by 92saturnsl2
06/22/18 02:37 PM
Bench Drill Press
by Propflux01
06/22/18 02:30 PM
IAT Sensor
by artbuc
06/22/18 02:26 PM
azzid0906, OilGeek91, DRancher, Newuser, Varbill
65299 Registered Users
90 registered (69Torino, Ag76, 9050lx, 330indy, 4WD, 2009Edge, 4 invisible), 1449 Guests and 47 Spiders online.
65299 Members
67 Forums
285801 Topics
Page 1 of 5 1 2 3 4 5 >
#4046433 - 03/23/16 12:29 AM 15-40 Oil?
Honda2003 Offline
Loc: Arkansas
Is it ok to run 15-40 oil in my 2001 GMC. It is z71 5.3 4x4 ex cab. I had a mechanic tell that I should run a thinker grade than I currently use. I use 5-30 now. Said he ran SuperTech 15-40 in everything he owns. I've thought about trying it because of my quart or more oil burning during 3000 mile oci. I've actually thought about switching to Delvac 15-40. I currently use Mobil Super 5-30 and used Maxlife 5-30 before that. Bought the truck new and it now has 213,000 miles it.
2001 GMC Extended Cab 5.3L Magnatec 5w-30 Synthetic
2013 Ford Edge Limited Motor Craft Syn
2007 Honda R 4x4 GN4 10W-30
#4046441 - 03/23/16 12:54 AM Re: 15-40 Oil? [Re: Honda2003]
mooferz Offline
Loc: TX
Keep using 5w-30. I think that's what GMC calls for.
If I were to run a thicker oil, I'd consider using a 5w or 0w-40 instead of 15w-40.
edit: Just noticed the oil burning, 10w30 could be a decent idea.
Edited by mooferz (03/23/16 01:08 AM)
2001 Lexus ES300, 235k mi, German Castrol 0w-40, Fram TG8316
1985 BMW R80RT (1L)- M1 15w-50
1993 Volvo 945 Turbo- Rotella T5 10W-30 (CJ-4)
#4046444 - 03/23/16 12:58 AM Re: 15-40 Oil? [Re: Honda2003]
bubbatime Offline
Loc: South Florida
The 5.3 is a full roller motor. It doesn't need thick. 15W40 will be fine, but I would stick with 5W30 myself.
If you are burning a quart per 3000 miles, switch to 10W30 maxlife, and maybe try their 10W40 if you really want to try a 40 weight.
17 Chrysler Pacifica Mobil 1 5W30
13 Yamaha XT250 Valv MC 10W40
12 Suzuki S40 Rotella 15W40
10 Acura TSX 2.4 PZL Plat 5W30
06 GMC Sierra Nextgen 10W30
#4046459 - 03/23/16 01:23 AM Re: 15-40 Oil? [Re: Honda2003]
FordCapriDriver Offline
Loc: Balearic Islands , Spain
try a 5w40
1975 Ford Capri II Ghia 3000 V6, - Valvoline VR1 20W-50
1988 Ford Escort MkIV 1.6 Xr3i Cabrio, - Shell Rimula R4X 15W-40 HDEO.
#4046488 - 03/23/16 03:35 AM Re: 15-40 Oil? [Re: Honda2003]
Garak Online   content
Loc: Regina, Saskatchewan, Canada
A 15w-40 is certainly acceptable. But, unless the specified 5w-30 is giving you real, tangible concerns, why change? Is your oil pressure low? Is it leaking out and a thicker oil would leak more slowly? Is it consuming oil? Try something like 15w-40 if you wish to address such issues. If you don't have such concerns, you'll be fine with what you're already doing.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
#4046504 - 03/23/16 04:03 AM Re: 15-40 Oil? [Re: Honda2003]
SR5 Offline
Loc: Down Under
Nothing wrong with 15W-40, it's probably the most common oil weight in Australia. 15W-40 mineral and 10W-40 semi-synthetic. We run it in everything.
Nothing wrong with a good 5W-30, but if you want to try 15W-40 it's not going to hurt your truck. You could always try it for one oil change and see, if you don't like it go back to 5W-30.
Penrite Vantage 10W40 SN & A3/B4 + Wesfil-Cooper Z154
#4046583 - 03/23/16 06:53 AM Re: 15-40 Oil? [Re: Honda2003]
A_Harman Offline
Loc: Michigan
No. Don't run 15w40. If your problem is oil burning, run M1 High Mileage 10w30 for at least a 6000 mile oil change interval.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
#4046594 - 03/23/16 07:04 AM Re: 15-40 Oil? [Re: Honda2003]
zrxkawboy Offline
Loc: SD
You live in AR and are burning oil - you could move up a grade if you want, though staying with 5W30 won't hurt, either. I'm sure 15W40 wouldn't hurt anything, but I might be inclined to try a 10W30 or 10W40 HM oil.
"Think of all the Ford owners who will someday want an automobile." John Dodge
#4046603 - 03/23/16 07:14 AM Re: 15-40 Oil? [Re: Garak]
Thebimmerfan Offline
Loc: East Europe
Yes, I think he said in the first post that the truck is consuming more than 1 quart in 3000miles.
#4046622 - 03/23/16 07:48 AM Re: 15-40 Oil? [Re: Honda2003]
mazdamonky Offline
Loc: Arkansas
My question is were you burning oil on Maxlife? you were using an HMO which is supposed to help with oil consumption but moved to Mobil super. Maybe try Mobil super High mileage? It can be had here in AR for $15.17 plus tax with a $7 mail in rebate at the time, so I see absolutely no harm in giving it a go. (if you have been using regular mobil super)
1985 rx7 1.1 98k miles
2002 protege 220k miles
1985 rx7 with a 5.0 swap
2002 Protege 292k miles Girlfriend's
4 more running cars in yard not mentioned
#4046630 - 03/23/16 07:54 AM Re: 15-40 Oil? [Re: Thebimmerfan]
krismoriah72 Offline
Loc: wv
The answer to your question is yes it is ok. I have had two service trucks that were run exclusively on 15w40 before i bought them. One a 5.4 ford and the other a 5.7 chevrolet. If you switch i would run a short cycle of 2500 miles or so at first due to the high detergents of the 15w40, your dipstick will be black from the cleaning.
#4046633 - 03/23/16 08:03 AM Re: 15-40 Oil? [Re: Honda2003]
mazdamonky Offline
Loc: Arkansas
Oh, Also, to answer your question, being here in Arkansas, I would Imagine 15w40 wouldn't hurt at all. Especially during the summer.
#4046658 - 03/23/16 08:29 AM Re: 15-40 Oil? [Re: zrxkawboy]
Bgallagher Offline
Loc: Boston, MA
+1 I worked for a landscape company when I was in college and he used 15w-40 shell in his entire fleet. Gas and diesel. We had an irrigation truck that had 300k on it and still purred like a kitten. Personally I don't see there being any issues but consider switching to a 10w-40 HM like Pennzoil.
2017 Chevy Traverse - 28k - Delco Dexos 1 and PF63
2014 Chevy Equinox - 22k - Delco Dexos 1 and PF457G
2015 GMC Terrain - 22k- Delco Dexos 1 and PF457G
#4046680 - 03/23/16 08:49 AM Re: 15-40 Oil? [Re: Thebimmerfan]
Thanks, don't know how I missed that. It might be worth a try, but that consumption isn't that high. It's on the border of what I'd consider annoying. wink
#4046757 - 03/23/16 09:55 AM Re: 15-40 Oil? [Re: mazdamonky]
Honda2003 Offline
Loc: Arkansas
Yes I was burning oil on Max Life. Quart or more on OCI 3000 miles. I've been on Max Life since 75,000 miles and now have 213,000. I just switched to the Mobil Super High Mileage 2 changes ago. No different than the max life and both 5-30.
