I just purchased a used 2011 Flex AWD with EcoBoost 3.5 engine and 108K miles. The previous owner gave me the service records and I found that her first Ford dealer was using a synthetic blend, 5W-30 for the first 43,000 miles. The owner then moved and her new Ford dealer used the standard, all Dino, 5W-30 oil at each oil change (ranged from 5000 to 7500 miles between changes)up to 108,000 miles.
I would like to switch to synthetic oil, but am not sure it that is wise at this point. Will I be subjecting the engine to any problems due to the sludge build up from the standard Dino oil? If I make the switch, I would appreciate your thoughts on what oil to use in this 3.5 EcoBoost engine.
Thanks,
JLaz
Thanks,
JLaz
