The vehicle has 94.5K miles on it (just bought it). Likely has the original fluid (volvo specifies "lifetime" factory fill, haha), which still has some red hue left in its brownish color and does not smell burnt. I think we're still at a safe place to begin this tranny on fresh fluids/cleanup.
I intend to do a drain-n-fill (which should get about 30-40% of the fluid) at 95K, and and start an ARX treatment at that time. At 100K I intend to do a flush using the low pressure tranny-cooler method made popular by volvo DIYers (can be seen demonstrated on youtube).
For that whole operation (drain and fill, followed by a drain-n-fill-n-flush) I'll probably be needing ~20 quarts of fluid, so price is a concern here but if there is a quality difference here I'm willing to cough it up.
Amalie Universal Synthetic Automatic Transmission Fluid (just under ~$6/qt on amazon, might be able to source it from a local tranny shop for less).
or
Mobile 3309 ATF (just under ~$6/qt on amazon)
or
Valvoline Maxlife Full Synthetic Multi-Vehicle ATF (~$4.40/qt from walmart)
I'm leaning towards the Amalie fluid, especially if I can source it locally for less. What would you use? Anything else I should have on my short list?
I'm somewhat hesitant on the Maxlife, as they mention in their application PDF that they have had reports of issues with this fluid in an Aisin 6 speed tranny, though I'm not sure how similar these transmissions are.
Thanks,
Eric
or
or
Thanks,
Eric
