Credit Increase- CC's
by Zee09. 02/21/19 08:24 AM
High iron and silicon
by landyman. 02/21/19 08:21 AM
13 Titan Vibration in 4th gear.
by Anthony. 02/21/19 07:36 AM
DEF Consumption
by wings&wheels. 02/21/19 07:06 AM
Which Natural Gas Water Heater to Get?
by LoneRanger. 02/21/19 06:58 AM
2016 Crosstrek Windshield Washer reservoir
by Donald. 02/21/19 06:43 AM
Whistling wipers!
by mclasser. 02/21/19 06:39 AM
Going by HTHS
by JLTD. 02/21/19 02:59 AM
Quick Struts vs Replacing the struts by themselves
by das_peikko. 02/20/19 11:50 PM
Walmart Oil clearance # 2
by GMguy84. 02/20/19 11:14 PM
ST Syn in a TGDI?
by BTLew81. 02/20/19 09:52 PM
The Virus That Kills Drug-Resistant Superbugs
by StevieC. 02/20/19 09:50 PM
Opinion Of Dodge Nitro
by Warstud. 02/20/19 09:26 PM
Cheap first car
by LeakySeals. 02/20/19 09:08 PM
Grand Caravan break in
by pda1122. 02/20/19 09:07 PM
Million mile Lexus
by Skippy722. 02/20/19 08:57 PM
AtomicNumber53, waynea, txan, pman9003, alienyouth33
67298 Registered Users
95 registered members (Al, alienyouth33, 2004tdigls, 1foxracing, Alfred_B, 13 invisible), 1,527 guests, and 53 spiders.
Topics284,600
Posts4,873,164
Members67,298
Most Online2,548
Feb 16th, 2019
Mazda 0W20 Synthetic 7000kms #3712968
04/27/15 04:15 PM
04/27/15 04:15 PM
Alberta
Dutchman Offline OP
Dutchman  Offline OP
Alberta
Hey I'm new here and see this isn't the way to post results, but I can't figure out how the chart works or how to add a picture.
What I do know is that oil should not look like this. First change was done at 8000kms and this is the result of oil change #2 with 7000kms.
Apparently the oil level was slowly creeping up the dip stick is how the customer found this.
3 Sodium
2 potassium
21 silicon
1 aluminum
20 iron
10 copper
0 lead
0 tin
1 chromium
0 nickel
o titanium
0 silver
0 vanadium
0 antimony
0 beryllium
1810 calcium
692 zinc
611 phosphorus
8 magnesium
181 molybdenum
168 boron
vis @ 40....45.2
vis @ 100....5.04
Fuel %.. 11.75
I see fuel is the culprit and the dealer is trying to find the problem. But what about long term affects of engine internals?? How can you tell if this hurt the engine? Has the damage been done or will this matter if problem fixed and oil flushed? Don't know how long it was like this, but customer regularly checks oil and brought in as soon as it was noticed. Vehicle is just a year old with 15,000 kms.
Just looking for some expert advise.
Re: Mazda 0W20 Synthetic 7000kms [Re: Dutchman] #3712992
04/27/15 04:32 PM
04/27/15 04:32 PM
MTL, CANADA
Rolla07 Offline
Rolla07  Offline
MTL, CANADA
Fuel dilution usually caused by not getting oil to temp..though I have never seen it this high. Please adviseus of driving habits and type/model/year of car. Will help us provide you with more accurate advice/info. Welcome to Bitog!
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
Re: Mazda 0W20 Synthetic 7000kms [Re: Dutchman] #3713014
04/27/15 04:51 PM
04/27/15 04:51 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
While your looking for answers and a solution you might consider a long, hard drive and/or changing the oil. That's a lot of gasoline in the oil.
PS Don't smoke while changing the oil on this car (lol).
Re: Mazda 0W20 Synthetic 7000kms [Re: Dutchman] #3713036
04/27/15 05:17 PM
04/27/15 05:17 PM
pa
jc1112 Offline
jc1112  Offline
pa
I have a mazda with high fuel dilution and it is sometimes the nature of the beast...
...but at 11.8% the oil is becoming way too thin i believe.
Wear is not too bad for 4400miles/7000km...
...but silicon is high, so this can be abrasive, it also could be residual wear-in.
I suggest an air filter change.
The oil level in my car does fluctuate up and down some but comes down with high speed
drives. It seems that 'your' mazda is idling a lot and may need an ecu reflash as
too much fuel is being dumped into the CC and past the pistons even though chromium
shows some ring seal.
Re: Mazda 0W20 Synthetic 7000kms [Re: Dutchman] #3713066
04/27/15 05:51 PM
04/27/15 05:51 PM
grande prairie AB
abycat Offline
abycat  Offline
grande prairie AB
honestly the report looks great. I bet it would last running just like this.
2017 dodge caravan gt
2011 nissan versa hb
Re: Mazda 0W20 Synthetic 7000kms [Re: abycat] #3713107
04/27/15 06:20 PM
04/27/15 06:20 PM
FL, USA
gregk24 Offline
gregk24  Offline
FL, USA
Yes, because 11.75% fuel and a viscosity of 5.04 at 100c is great! F-A-C-E-P-A-L-M
2012 Honda Accord EX-L K24z3
56,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
44,xxx miles
Castrol OEM dealer fill / OEM filter
Re: Mazda 0W20 Synthetic 7000kms [Re: Dutchman] #3713122
04/27/15 06:35 PM
04/27/15 06:35 PM
Florida, Cape Coral
Eddie Offline
Eddie  Offline
Florida, Cape Coral
I would suspect leaking injector or fuel pressure too high. My CX5 has never shown over 1% fuel. Something is wrong. Have Blackstone run the analysis again to confirm. Ed
CX5 Touring 2.5L :-)
Re: Mazda 0W20 Synthetic 7000kms [Re: gregk24] #3713151
04/27/15 07:00 PM
04/27/15 07:00 PM
grande prairie AB
abycat Offline
abycat  Offline
grande prairie AB
what exactly is it hurting? wear metals are fine especially for the second change ever. I've seen 4x as much wear metals on a 100k engine still. Give me some indication that it is hurting the engine and I'll facepalm myself but until then I think this is just what you will see for certain di engines.
Re: Mazda 0W20 Synthetic 7000kms [Re: Dutchman] #3713285
04/27/15 08:59 PM
04/27/15 08:59 PM
Western Canada
geeman789 Offline
geeman789  Offline
Western Canada
First we had 3000 mile OCI's... then we learned that oil has improved along with engine tech., and OCI's became longer and longer... low maintenance, save the planet etc....
Now, with DI engines, it seems we should be moving back to shorter OCI's...
Better....? Maybe, until you need to clean the intake valves...
2011 SUBARU Impreza 5 spd manual / 2016 Honda Pilot
Re: Mazda 0W20 Synthetic 7000kms [Re: Dutchman] #3713413
04/28/15 01:56 AM
04/28/15 01:56 AM
Maple Syrup Land
Stewie Offline
Stewie  Offline
Maple Syrup Land
Isn't this normal for DI engines??
10% is probably b/c you short tripped too much
Re: Mazda 0W20 Synthetic 7000kms [Re: Stewie] #3713540
04/28/15 06:44 AM
04/28/15 06:44 AM
KC
badtlc Online content
badtlc  Online Content
KC
No.
2007 Ford Escape XLS 2.3L ATX, M1 AFE 0W20, Fram TG, 167k
2015 Chrysler T&C, 87k+, M1 AFE 0W20, Fram TG OF
2018 Forester Premium 3k+, Factory 0W20, Factory OF
Re: Mazda 0W20 Synthetic 7000kms [Re: Dutchman] #3715102
04/29/15 12:53 PM
04/29/15 12:53 PM
Alberta
Dutchman Offline OP
Dutchman  Offline OP
Alberta
Ok, to update, yes this is a 2.5L skyactive DI.
There is a fair amount of city driving, but also does the occasional highway run. Definitely doesn't sit there idling for an hour warming up in winter.
It was at the dealer for a check up. They reviewed the report and could not find why it was diluted. They did every electronic check available via their scanner/computer and said everything is registering correctly. They tell me the sensors would pick up the extra fuel. Well obviously they don't.
Since the change of dirty oil, it has been driven 800kms, and no apparent problems. The dealer did another oil/ filter change at this time, and they said to monitor it. A file has been started with mazda to get their input.
Dont know if this was sudden, or been there for a long time. I started this thread because I know nothing about oil specs and wanted some idea if this was going to hurt the engine long term.
Re: Mazda 0W20 Synthetic 7000kms [Re: Dutchman] #3715115
04/29/15 01:08 PM
04/29/15 01:08 PM
KC
KC
Your car is operating perfectly fine if you are running 87 octane. The ECU has to run very rich to cool the combustion chamber enough for the high pressures or you will get detonation with 87. It has to run pig rich on 87 octane.
If you want to fix the fuel dilution even though there is no evidence of it being a problem, run premium unleaded (91+ octane).
Don't stress. Your car is fine!
Moderated by  ekpolk
