Originally Posted By: fourside
Sustina 0w20 is very popular in this motor and UOA's have shown it's a great fit. It's expensive, but arguably the ideal oil for the motor and OCI's can be extended to make up for the cost a bit.
Here's one UOA of Sustina 0W-20 on a tracked FR-S in Florida:
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3151637/1
But TGMO 0W-20 is almost as good and of course is cheaper and more easily available.
For track use when oil temp's can get very high, the solution is not a heavier grade but to install an oil cooler. That's always the preferred solution for many reason. The positive effects of installing an oil cooler in a FR-S/BRZ was mentioned in the Sustina UOA.
