Does anyone have second citizenship?
by Martula - 11/14/19 10:38 PM
2019 i30 Nline 1.6T and first service (1500km)
by rov137 - 11/14/19 10:11 PM
Garbage Disposal Replacement
by bunnspecial - 11/14/19 09:58 PM
Nest thermostat
by miden851 - 11/14/19 09:06 PM
2011 G37X
by maverickfhs - 11/14/19 08:27 PM
Recommendations for oil filter
by dawgn86 - 11/14/19 07:38 PM
2001 Subaru Outback $2,300 OBO
by 14Accent - 11/14/19 07:16 PM
Brake Friction Code List
by 92saturnsl2 - 11/14/19 07:14 PM
Accord reached a milestone today!
by mclasser - 11/14/19 06:59 PM
Is an alignment absolutely needed after new tires?
by SouthDakotaDad - 11/14/19 06:11 PM
Redline Professional Series 5w20
by burla - 11/14/19 06:00 PM
Backup Camera
by George7941 - 11/14/19 05:26 PM
'11 Prius 15k OCI Amsoil 0W-20
by mdv - 11/14/19 05:16 PM
Lightweight easy up
by Redright9 - 11/14/19 05:00 PM
Thinking of getting a cat
by 53' Stude - 11/14/19 04:42 PM
Apple Watch users
by madRiver - 11/14/19 03:05 PM
It's here, arrived early still 1 week to wait
by BeerCan - 11/14/19 02:20 PM
Cooling leaks at hose to housing connections
by Fitz98 - 11/14/19 12:53 PM
rov137, Dorisy, DesktopDave, HPD, kildeth
69868 Registered Users
56 registered members (14Accent, AndyB, 2003f7, Bailes1992, Astro14, 3 invisible), 1,379 guests, and 27 spiders.
Topics297,431
Posts5,115,472
Members69,868
Most Online3,589
Nov 2nd, 2019
Honda CRV transmission?? #3467812 08/28/14 06:44 PM
L
lawman1909 Offline OP
L
Hello all, I have narrowed down my next vehicle to a 2014 Honda CRV LX. Do these have "lifetime sealed transmissions" where you supposedly cant drain the fluid. Anyone know my answer?
2014 Honda CR-V AWD LX
M1 0W-20 EP/Fram Ultra 7317
Bless all LEO's, Fire, EMS, and military personnel both active and retired. USA! USA!
Re: Honda CRV transmission?? [Re: lawman1909] #3467822 08/28/14 06:51 PM
M
Miller88 Offline
M
Any fluid is changeable - they all have drain/fill plugs. It's just a way for them to get lower maintenance costs. If you truely do plan on keeping it, do a drain/fill with Honda OEM ATF every 30K and be confident that it will go 150+ miles.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Honda CRV transmission?? [Re: lawman1909] #3467832 08/28/14 06:58 PM
R
rjundi Offline
R
It has a simple drain/fill affair. I believe the Oil Life Monitor tells you when it should be changed out. I found it easy to change my MDX fluid DIY however my mechanic only charges $13 labor if I supply the fluid so a no brainer.
Re: Honda CRV transmission?? [Re: lawman1909] #3467850 08/28/14 07:07 PM
J
JOD Offline
J
Nope, same as always--drain through the drain plug, fill through the dipstick. Everything is accessible, and it's easier than an oil change. While Honda transmissions get a bad rap, the CRV has always had reliable transmissions. It seems Honda are extra-cautious with that vehicle. It was the last to get a 5 speed, and it never did even go to 6, let alone the CVT. Seems they want to be certain they don't screw up that one...
Re: Honda CRV transmission?? [Re: lawman1909] #3467934 08/28/14 08:46 PM
dernp Offline
You don't even need to put the vehicle on ramps. You can do ATF drain and fills while the car is on the ground. One drain and fill takes 3 qts Honda DW-1.
2018 Rav 4 Limited Amsoil SS
2019 Tundra 5.7L TRD Off Road FF
Re: Honda CRV transmission?? [Re: lawman1909] #3467962 08/28/14 09:23 PM
G
gregk24 Offline
G
Honda has made it easy to change the trans fluid on most of their line up. Unscrew drain plug, screw on, fill with 3 quarts of ATF DW1. Easier than an oil change.
2012 Honda Accord EX-L K24z3
59,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
51,xxx miles
Castrol Edge 0w40 / OEM filter
Re: Honda CRV transmission?? [Re: lawman1909] #3468192 08/29/14 07:58 AM
H
Hokiefyd Offline
H
If you get it, I think that you'll find that all fluid sumps on it are easily accessible. Whether that's the engine oil and filter, the transmission drain plug, the rear differential drain plug if you get an AWD version, or the engine coolant. Both of our cars seem designed with DIY maintenance in mind, and I like that about them.
Re: Honda CRV transmission?? [Re: lawman1909] #3468465 08/29/14 01:01 PM
cptbarkey Offline
whos to say you dont drill your own holes to drain / fill anyway. given the knowledge and willpower smile
