There are 4 speeds at which I can 50mph, engine speed makes no difference.
I have also run the car in gear while up on a lift.
Nada.
The drive-shaft was changed because the Stock unit used a CV joint at one end, that did show some wear.
A new shaft was made up by a reputable shop that specializes in Drive-shafts.
No change.
The engine runs perfectly. This is a fully balanced (to within 1/10 of a Gram) engine, Carburetors (Twin SU) and ignition (Nippondenso electronic) are fully sorted.
Nada.
No change.
