Brake bleeder - cfm ?
by hallstevenson. 09/25/18 09:43 PM
18' Corolla vs 18' Elantra
by wolf_06. 09/25/18 09:41 PM
Using Tc-w3 bad for my car?
by Floydian. 09/25/18 09:25 PM
I'm going to start using type F in my gm autos
by turtlevette. 09/25/18 09:17 PM
Cleaning deceased MIL condo and found $15K cash
by Mr Nice. 09/25/18 09:12 PM
Gluten
by StevieC. 09/25/18 07:55 PM
Amazon Prime delivering inside your house
by StevieC. 09/25/18 07:49 PM
2018 MB C300 M1 0W-40 3,475 Miles
by 2015_PSD. 09/25/18 06:44 PM
02-05 Silverado frame rot
by Oildudeny. 09/25/18 06:38 PM
Aftermarket Back Up Camera
by lancerplayer. 09/25/18 06:20 PM
Service champ filter CUT OPEN
by 53' Stude. 09/25/18 05:05 PM
Pressure washer pump life just 23 hours?
by HawkeyeScott. 09/25/18 05:01 PM
STP S 10590 CUT OPEN
by 53' Stude. 09/25/18 05:00 PM
2003 BMW M5-Unknown oil 2500 mi
by Audios. 09/25/18 04:54 PM
FRAM ULTRA XG 3593A CUT OPEN
by 53' Stude. 09/25/18 04:51 PM
MG 201-7, 7,500 MILES CUT OPEN
by 53' Stude. 09/25/18 04:44 PM
MG 301-1, 10,800 miles CUT OPEN
by 53' Stude. 09/25/18 04:34 PM
Anyone regret their cordless electric OPE?
by dlundblad. 09/25/18 04:21 PM
Which Performance Filter?
by rooflessVW. 09/25/18 03:33 PM
Pat_Roberts, Peppz, Jfa02, ibsfusion, Fearcat707
66070 Registered Users
110 registered members (Armkb, 77GrandPrix, 92saturnsl2, Ablebody, aquariuscsm, ABomb369, 11 invisible), 1,318 guests, and 32 spiders.
Topics291,019
Posts4,854,532
Members66,070
Most Online3,590
Jan 24th, 2017
Page 1 of 3 1 2 3
2012 Honda Civic AT - Which Lubegard? #3206561
12/04/13 08:45 PM
12/04/13 08:45 PM
Colorado
sw99 Offline OP
sw99  Offline OP
Colorado
Spent quite a while looking on the interweb but have found so much conflicting info on which LG to use. I am running Maxlife ATF in lieu of the Honda DW-1. I am running the same fluid in my 2001 Corolla with the same Maxlife ATF with the LG red and it shifts great. I keep reading LB silver, black, red and so forth for the Honda's...
No shifting issues with the Honda, I just like the added protection of keeping the tranny temps down. I am going to do the drain and fill every year or so. Since I'm running Maxlife ATF, I can't see why I can't use LG red and be done with it.
2016 Nissan Versa S 1.6L
2018 Subaru Outback 2.5i
2018 Ford F350 6.2L
Re: 2012 Honda Civic AT - Which Lubegard? [Re: sw99] #3206569
12/04/13 08:49 PM
12/04/13 08:49 PM
FL, USA
gregk24 Offline
gregk24  Offline
FL, USA
No reason at all to use anything else than Honda DW-1. And certainly no reason for lube guard.
2012 Honda Accord EX-L K24z3
54,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
40,xxx miles
Castrol OEM dealer fill / OEM filter
Re: 2012 Honda Civic AT - Which Lubegard? [Re: gregk24] #3206576
12/04/13 08:55 PM
12/04/13 08:55 PM
Colorado
sw99 Offline OP
sw99  Offline OP
Colorado
Thanks but I refuse to use DW-1. Lower tranny fluid temp is a good reason to use LG but thanks for posting.
2018 Ford F350 6.2L
Re: 2012 Honda Civic AT - Which Lubegard? [Re: sw99] #3206587
12/04/13 09:04 PM
12/04/13 09:04 PM
FL, USA
gregk24 Offline
gregk24  Offline
FL, USA
Well its your choice. DW-1 is a low viscosity fluid with special additives for newer Honda transmissions. While Maxlife ATF has shown to work well in other Honda transmissions it doesnt mean it should be your fluid of choice for the life of your Honda. Its more of a "universal" atf, not spec'd for your Honda (even though it says "approved" on the bottle for Z-1 it wasnt approved by Honda themselves). But again, your car your choice. If I didnt use DW-1 I would probably use Valvoline Import ATF, or Castrol Multi Import.
54,xxx miles
40,xxx miles
Re: 2012 Honda Civic AT - Which Lubegard? [Re: sw99] #3206594
12/04/13 09:08 PM
12/04/13 09:08 PM
Fresno, CA
david_ES2 Offline
david_ES2  Offline
Fresno, CA
A little overkill if you already do a drain and refill frequently
2004 Honda Civic EX K20Z1 5w30 PP WIX XP
Re: 2012 Honda Civic AT - Which Lubegard? [Re: sw99] #3206608
12/04/13 09:15 PM
12/04/13 09:15 PM
Colorado
sw99 Offline OP
sw99  Offline OP
Colorado
Overkill yes but like I mentioned the lower tranny temps are a huge benefit. Plus LG is like $10 a bottle and I use half a bottle on the drain and fills.
Maybe it's just me but the civic shifts better than ever after adding the maxlife.
2018 Ford F350 6.2L
Re: 2012 Honda Civic AT - Which Lubegard? [Re: sw99] #3206613
12/04/13 09:17 PM
12/04/13 09:17 PM
CT USA
MajorCavalry Offline
CT USA
Just out of curiosity, why do you refuse to use DW-1? I use it in my 2012 Acura TL. It is supposed to be a much better formulation than the old Z-1.
Steve
2015 Lexus GS 350 CPO
12K miles
Just purchased.
2016 Lexus IS 300 AWD (gone, just too small)
16K miles
Castrol Edge 0W-20
Toyota filter
Re: 2012 Honda Civic AT - Which Lubegard? [Re: MajorCavalry] #3206618
12/04/13 09:23 PM
12/04/13 09:23 PM
Colorado
sw99 Offline OP
sw99  Offline OP
Colorado
Maxlife is $16 a gallon and im my opinion works just as well. Nothing against it I just feel that ML is every bit as good for less $.
2018 Ford F350 6.2L
Re: 2012 Honda Civic AT - Which Lubegard? [Re: sw99] #3206623
12/04/13 09:27 PM
12/04/13 09:27 PM
FL, USA
gregk24 Offline
gregk24  Offline
FL, USA
What proof do you have that LG lowers transmission temperatures?
54,xxx miles
40,xxx miles
Re: 2012 Honda Civic AT - Which Lubegard? [Re: sw99] #3206631
12/04/13 09:32 PM
12/04/13 09:32 PM
Indiana
Phishin Offline
Phishin  Offline
Indiana
I don't know about Hondas..... because I'll use DW-1 in mine, but in my Nissan and K1500, both get ML and 2 bottles each of LG Red.
2018 Chevy Silerado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: VSP 0w20/MaxLife 10w30 + LG BioTech HD
2014 CR-V LX K24: M1 0w30
Re: 2012 Honda Civic AT - Which Lubegard? [Re: sw99] #3206633
12/04/13 09:32 PM
12/04/13 09:32 PM
usa
tommygunn Offline
tommygunn  Offline
usa
Wow you have to change it already? Aren't you still under warranty? If so, just wait until the MM tells you to change it, and use DW1. Once the warranty expires, use Maxlife, or Mag 1 synthetic low-vis ATF, according to the MM's suggestions.
And you really shouldn't need any Lubegard on a brand new car!
How many miles does it have?
i am a [censored] who hides behind bugmenot.
i also like applying negative pressure to a certain male appendage.
Re: 2012 Honda Civic AT - Which Lubegard? [Re: gregk24] #3206638
12/04/13 09:36 PM
12/04/13 09:36 PM
Colorado
sw99 Offline OP
sw99  Offline OP
Colorado
I have no scientific proof but from what I have seen and read, I really don't feel the need to look into it more.
http://www.lubegard.com/pdfs/HeatChart%28AL-516%29.pdf
BTW, I'm not looking for a LG debate.
2018 Ford F350 6.2L
Re: 2012 Honda Civic AT - Which Lubegard? [Re: tommygunn] #3206642
12/04/13 09:37 PM
12/04/13 09:37 PM
Colorado
sw99 Offline OP
sw99  Offline OP
Colorado
Out of warranty, drain and fill was done at 34k.
2018 Ford F350 6.2L
Re: 2012 Honda Civic AT - Which Lubegard? [Re: sw99] #3206685
12/04/13 10:06 PM
12/04/13 10:06 PM
CFL
mikefxu Offline
mikefxu  Offline
CFL
We also have a 2012 Civic with 48k now. I am doing DW-1 every 30k since I do it myself. I would never consider putting anything other than DW-1 in it. 2007 Civic at work had no problem taking factory fill to 100k.
Re: 2012 Honda Civic AT - Which Lubegard? [Re: sw99] #3206693
12/04/13 10:14 PM
12/04/13 10:14 PM
southern mo
ram_man Offline
ram_man  Offline
southern mo
if you want to lower trans temps add a cooler. magic potions aren't going to do anything to benefit you In this case. also dw1 is a much better fluid than the old z1.
also not trying to be rude but the majority of people are telling you not to use lg because in this situation its a waste of money with zero benefit and to use dw1 because this will benefit you and you just refuse to do that. if you already have your mind made on it why post here about what we would use?
if you insist on using lg use the cheapest one because none of it is going to do anything. lg is a decent product when used for the right reasons. but I doubt it will lower temps very much if at all. your car just needs the proper fluid at the proper interval. if you want peace of mind change it a little earlier than necessary. I change mine every 20,000. I want to keep very clean fluid in it because I don't trust slush boxes and don't want to have to replace it. however there is no proof my change interval is a benefit at all but it makes me feel a little better.
2014 dodge dart GT
1995 Dodge ram 1500
Page 1 of 3 1 2 3
