Originally Posted By: eagle23
...Some folks like DW-1, and that's fine but it's predecessor was truly junk. The old trope "only use Honda ATF in Hondas" is flatly untrue. I suspect many who trot that out don't own Hondas and never have....
Difficult for me to find fault with that statement. Though I used Z-1 exclusively in an 01 Civic till superseded by DW1, Z1 is now proven to have sheared very quickly and was truely nothing special as an ATF. DW-1 is supposed to be an improvement, though based on Z1 record, that wouldn't take much. I'm sure if one hangs out at the Honda specific forums, much as Z1 was always the only fluid to use DW-1 is the same being that it replaces Z-1, because Honda always knows best. Right? At least that's what the kool aide drinkers would have one believe.
I will say if my Honda was still under warranty I'd likely still use DW1 just to eliminate any possible question should there be any kind of AT issue. Based on Honda's less than stellar AT reliability record, seems prudent. That said, I'm now using MaxLife in two Hondas spec'd for Z-1, working just fine thank you.
If out of warranty (which the OP says he is) and the OP is comfortable and confident with ML and Lubegard (Red or Platinum), then I say go for it. Based on reading many posts on bitog both products are respected and used successfully.
As for the OP's question, seeing as it's not CVT either the standard Red or the Platinum is appropriate. The latter adding CVT to it's product information spec sheet.
