It is hard for me to comprehend wasting time and money on routine oil drains. I get highly irritated waiting in the local oil change business to get a safety inspection sticker. The last time I took my old Ford diesel in for a safety inspection they almost pulled it in and drained the oil.
I got off the poor filtration dirty oil and oil change merry go round 40 years ago. I've never looked back. It took me 18 years to put 240,000 on a Subaru. I changed the plugs a couple of times. I gave it to a friend and told him it is leaking about a qt of oil every 1,000 miles but it runs strong. It had no full flow filter. I changed the Frantz once a year and added a qt of Mobil 1. I actually should have changed the filter and added one qt of oil every 4,000 miles. There is a man here that drives a lot miles. He put over 500,000 on his Toyota Corolla before trading it off. Pennzoil 30 wt.
My experience is with the Frantz, Motor Guard and Gulf Coast submicronic bypass filters. The Motor Guard is the easiest to service without spillage. A man with a lot more experience with Toyotas than I have tells me the transmisssion will probably go before the engine. I have the Motor Guard ATF transmisssion filter which is the easiest to install. I have a lot of metal out of the filter the first time I changed it. It has been clean since. Hopefully I have virtually stopped the wear.
As far as Bosch filters, they remove the big stuff like the others. None of my engines have any big stuff in the oul. The big stuff is caused by not taking care of the small stuff.
Ralph
