Originally Posted By: BlueOvalFitter
Originally Posted By: gathermewool
Originally Posted By: LScowboy
Originally Posted By: RevRider
Is this any reason why you can't change your oil filter every other time if you are using a high capacity filter like M1, Amsoil, Puralator synthtetic, etc., and only going 4k to 5k on oil service intervals?
sure, if you don't mind all that black dirty oil in your filter staying in your engine along with the nice new oil
I think if I was gonna save a few bucks reusing a filter, I would at least dump it out at the oil change.
What kind of oil are you using and/or how badly is your engine running that you're worried about a little bit of leftover oil in the filter?
For reference, our Civic takes 4 quarts and the amount indicated on the dipstick after adding 4 quarts of oil, with or without an oil filter change, is very small - I add the same amount of oil at each oil change, regardless of whether I change the filter, too.
So, with a Fumoto valve installed, changing only the oil is incredibly easy. I use a better-built filter that gives ME a warm and fuzzy from the beginning aaaaaaaaall the way to the end of its second interval, and only have to change it ~ once/year sounds like pretty good economy to me
So, with a conventional drain plug and using a wrench to remove it, changing the oil is easy, to me anyway. I use a MC filter, but can use any brand I choose to, and I get that same warm and fuzzy feeling from the beginning, aaaaaall the way to the end of its 1 and only interval use! And, I change them at every OCI because I can, and want to.
To each his or her own. I've successfully, messlessly done many "conventional" changes. For me, turning a ball valve 90° and working on other things while the oil drains is about as easy as it gets.
If I sent out a sample for analysis that showed I could go 2X my current MM-directed OCI, the I would be changing the oil and filter at the same time, most likely. So, it's all relative, really. For some one who changes both his/her oil and filter at 5k miles, then their OCI would be 5/7th mine; the OFI 5/14th mine. The odds are with us, that none of us will experience an oil-related issue. So, whether you still do $50 oil changes every 3k or a mix of oil and filter changes that extends well beyond that, it doesn't matter. Again, to each his or her own
