Originally Posted By: Clevy
This is true however one of the guys in my crew bought a 2013 mustang last year. It was the first one delivered to a customer in the west. We promptly took it to the track and beat on it. We did 20 passes to break in the engine. Then we went to the small oval we have here in Saskatoon and drove that car to its limit and could NOT get it to go into limp mode. The oil system doesn't have a cooler stock but I can tell you from experience that we drove that car so hard we put a dent in the floor and we couldn't get the oil so hot that it neutered the engine.
So yes those safeguards are in place but it would take some serious ambient temps coupled with the most extreme hard driving imagineable to force it into limp mode.
We ran 20 consecutive laps,with only a few minutes in between to let the engine cool off so as far as I'm concerned we were hot lapping the car,and we couldn't get it to go into limp mode.
Ford engineering got the stock gt right for sure. I don't know what it takes to force it into limp mode but we couldn't do it.
And it had the factory 20 grade in the sump. We changed the oil after that weekend and it was black but we put 4000 really hard kms on it in 4 days. We were in it for 14 hours a day. He also needed new rear tires,which we put dot legal drag slicks.
Surprisingly enough when we cut open the oil filter there was no metal that we could see and the oil didn't smell like fuel. It was a quart low though.
It's been a while since I've looked at it, but there are OT tables in the Copperhead PCM and I believe they become progressively more aggressive as oil temperature climbs. We logged some quickly climbing oil temps with a Vortech 2012 5.0 during some 7500 rpm dyno pulls, IIRC.
I don't remember if the vortech unit was a sealed and lubed for life or is it fed oil from the sump.
I can certainly believe that on a dyno,running some decent boost the oil temps could climb very quickly. We were outside in the open air and his car was stock,basically right off the trailer and to the drag strip b
How do the new 5.0s like the snails. I prefer the twin screw type simply because I'm hooked on torque but I would love to feel a snail pulling one of those cars around.
Awesome!
Vortech's new superchargers are filled with synthetic fluid (internally lubricated)and include an integrated dipstick to keep an eye on the fluid.The older Vortechs,you had to punch a small hole in the front of the oil pan for the blowers lubrication(very simple painless process).I've got the older style of Vortech, and have had "0" issues as with most people who run Vortech's
Awesome!
