Originally Posted By: electrolover
Originally Posted By: threeputtpar
Same diff on my Mountaineer. I recall it takes just under 1.5 quarts to refill. Total capacity of the diff is 1.8 quarts, but with the drain plug not all of it comes out.
I intentionally raised the front up when draining the rear diff and I still couldn't get more than 1.5 quarts back in, FWIW. I didn't think it was necessary to remove the cover just for that last little bit.
If you don't have a 3/4 ratchet, HF has a set of adapters that has a 1/2 female x 3/4 male in it.
When the dealer did it, they charged me for 3 qts. So im guessing it held 2 1/2 unless they just wanted to run the bill up. It was $300 for the seals and fluid change...
Amsoil's website says your diff holds 5.5 pints, or 2.75 quarts so no stealership tactics here.
