CV Joint Leaking Grease
by 92saturnsl2 - 08/22/19 10:20 PM
Craftsman 6 pc. Screwdriver Set $12.14
by Warstud - 08/22/19 09:32 PM
Got My ATF Replaced.
by Mr_Luke - 08/22/19 09:20 PM
Wht do people with labor intensive jobs lay on their back?
by motor_oil_madman - 08/22/19 09:14 PM
Date code 5 Q Chevron location?
by Onetor - 08/22/19 08:06 PM
Confused, what oil to use?
by BelAir - 08/22/19 08:00 PM
2015 KIA optima turbo Coolant Flush
by Grambo - 08/22/19 07:52 PM
Motul 300V -- oops
by xr650boy - 08/22/19 06:35 PM
Evolution of Garbage Trucks...joke thread
by GumbyJarvis - 08/22/19 05:57 PM
What is this Oil's Application?
by MolaKule - 08/22/19 05:19 PM
Ford 2.5L Engine and 6F35 Transmission
by drh214 - 08/22/19 04:57 PM
Fram XG7317 vs XG3593A
by gamefoo21 - 08/22/19 03:59 PM
Carquest premium 85334
by SlavaB - 08/22/19 03:47 PM
Oil for a Ford 2.8 L Cologne V6
by ford4wd08 - 08/22/19 03:46 PM
Good Question?🤔
by Mad_Hatter - 08/22/19 01:40 PM
Autozone misinformation?
by NavyVet88 - 08/22/19 11:23 AM
Did I mess up getting a civic that sat?
by Kurtatron - 08/22/19 10:48 AM
What are these two things in the bumper?
by atikovi - 08/22/19 09:48 AM
Amsoil Metal Protector
by Snagglefoot - 08/22/19 09:07 AM
PTL, vdubw, NJ01MGM, Antiquity, tundraotto
69034 Registered Users
39 registered members (clinebarger, BusyLittleShop, carlprop, alchargo, cdlamb, Ag76, 3 invisible), 966 guests, and 25 spiders.
Topics293,664
Posts5,044,635
Members69,034
Most Online3,532
Jul 30th, 2019
Page 7 of 9 1 6 7 8 9
Re: hy-per lube zinc replacement additive [Re: MolaKule] #3597423 01/12/15 01:22 PM
CrawfishTails Offline
Originally Posted By: MolaKule
Originally Posted By: CrawfishTails
Would the HyperLube Zinc-replacement stuff compete with the other AW additives in a fully formulated oil (i.e., Mobil1)? I noticed some researchers said you can't just add Ionic Lubricants (ILs) to fully formulated motor oil, as it competes for the surface with what normal motor oils already have. Can we assume Hyperlube is not going to work based on the experience with IL ?
The HyperLube in question is not an Ionic Liquid and does not compete with other AW additives but is synergistic.
OK, sounds like HyperLube no-zinc formula (ester) is the real deal. No way to tell once I put it in the oil, as my butt-dyno is only sensitive to anything above 2.8 on the Richter scale. I'll use MolaKules recomendation of 1 oz per quart motor oil, since any decent oil already has the SN limit of zddp there.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #3601107 01/15/15 02:43 PM
MolaKule Offline
Global Moderator
Global Moderator
I doubt there will be any "butt-dyno" effects on the Richter scale smile as it is not a friction modifier but an additional anti-wear additive.
For the daily driver using a good OTC oil, I see no reason to use it.
If you are concerned about wear during tracking, it may help reduce wear.
But if I were tracking, I think I would use a high ZDDP oil similar to Amsoil's Z-Rod or Dominator racing oils.
The only reason I discuss this at all is because I have used a similar chemistry in a low-vis formulation with 300 ppm of ZDDP and a polymer chemistry, and wear results were good.
The value of a scientific theory is its ability to prompt further study, not that it has any relation to the established facts of scientific reality.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #3601124 01/15/15 03:01 PM
If we believe Hyperlube's own cam wear tables, this stuff can boost wear performance. MolaKule's good experience and some articles I read seem to corroborate the good effects. I'm looking for anything to reduce wear over what dexos1, MB 229.5, etc. already requires.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #3608299 01/22/15 10:04 AM
K
Koz1 Offline
K
Are there any similar products that are at a better price point?
Currently using, 8100 X-clean EFE 5W-30, M1 5W-20 and Castrol Edge 0W-20 Gold B.
Re: hy-per lube zinc replacement additive [Re: Koz1] #3608746 01/22/15 03:38 PM
MolaKule Offline
Global Moderator
Global Moderator
Not at this time.
The polymer ester is expensive.
Re: hy-per lube zinc replacement additive [Re: MolaKule] #3608898 01/22/15 06:10 PM
K
Koz1 Offline
K
Thank you.
Cheers.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #4743999 04/30/18 10:33 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Did we ever get to the bottom of if this stuff and Schaefer 132 have similar chemistry and concept of use/protection?
I found a good number of 132 bottles in my garage. Might start dosing it into my 20wt oils...
Re: hy-per lube zinc replacement additive [Re: DanMiller] #4744532 05/01/18 02:18 PM
MolaKule Offline
Global Moderator
Global Moderator
HyperLube Zinc Replacement is a pure polymer ester, nothing else.
Schaeffer's #132 is mostly an oil thickener (VII) with some ester mixed in and these components:
Moly 25
Phosphorus 120
Zinc 10
Antimony 64
Vi @ 100c 220
It is used primarily in diesel and gasoline engines with worn rings and worn valve stem seals, AKA, "smokers."
Re: hy-per lube zinc replacement additive [Re: MolaKule] #4744695 05/01/18 04:44 PM
demarpaint Offline
Moly 25
Phosphorus 120
Zinc 10
Antimony 64
Vi @ 100c 220
Will a full bottle added to M1 or PP 5w30 push it to a 40 grade? Thanks.
God Bless Our Troops
Re: hy-per lube zinc replacement additive [Re: demarpaint] #4744767 05/01/18 06:12 PM
O
oil_film_movies Offline
O
Schaeffer's #132 Moly EP certainly will take a 5w30 to a 5w40 or 10w40, easily with 16 oz in 1 bottle (assume 5 qt sump).
HyperLube ZRA has a KV100 of about 37, if I converted the MSDS's dynamic visc at 100 correctly to kinematic visc; Therefore, you get a +1 cSt boost from HyperLube ZRA at 12 oz in a 5qt sump, so it does not quite make it to a 40 weight.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #4744826 05/01/18 07:17 PM
B
benjy Offline
B
interesting for sure, i like many are trying to "reinvent the wheel" with todays declining additives something to add a bit more protection is interesting. i have blended Redlines high moly oils with Mobil I EP both 10-30 + wondering if this helps or hurts anything more than my wallet!!!
Re: hy-per lube zinc replacement additive [Re: oil_film_movies] #4745171 05/02/18 05:05 AM
demarpaint Offline
Thanks, I figured the #132 would give it a bump, too much for my liking. I guess it really is for oil burners only, unless cut with something.
Re: hy-per lube zinc replacement additive [Re: demarpaint] #4745225 05/02/18 06:26 AM
spasm3 Offline
I have used schaffer's 132 50/50 with motor oil as an assembly lube. Seems to stay put on cylinders when installing pistons/rings and for start up.
13 elantra 78k 5w30 synpwr
17 mazda cx-5 12300 miles m1 0w30
Re: hy-per lube zinc replacement additive [Re: DanMiller] #4745229 05/02/18 06:34 AM
spasm3 Offline
Mola, would there be any advantage in using the hyperlube zinc replacement ester with engines that are known for fuel dilution?
Re: hy-per lube zinc replacement additive [Re: spasm3] #4745241 05/02/18 06:57 AM
demarpaint Offline
thumbsup
