Bank 1 on an Equinox
by Washoe_Mark. 03/20/19 08:47 AM
How do you pronounce the word Vehicle?
by ZZman. 03/20/19 08:21 AM
Inline Fuel Filter
by CCI. 03/20/19 08:08 AM
Are All Douglas Tires USA Made?
by Miller88. 03/20/19 07:30 AM
Turn signal bulbs for '15 BMW?
by Benzadmiral. 03/20/19 07:02 AM
Drain/refill vs diy flush?
by Back40. 03/20/19 05:59 AM
Valvoline 5w30 Synpower HSTS?
by avi1777. 03/20/19 05:05 AM
Castrol Edge 5W50 "Supercar Titanium FST"
by Berto. 03/20/19 02:43 AM
The power of reaching out
by SlavaB. 03/20/19 12:57 AM
Used brake fluid
by OilUzer. 03/19/19 11:26 PM
Look what I found
by deven. 03/19/19 11:23 PM
91 E-free, or 91 "up to 10%" for GDI?
by Ws6. 03/19/19 11:12 PM
Ford 2019 F350 oil
by arowbat. 03/19/19 11:04 PM
Royal purple discontinuing 30-1218 ?
by jmj540. 03/19/19 10:02 PM
Nissen Radiator Review
by zmelli. 03/19/19 09:01 PM
March madness
by gman2304. 03/19/19 08:36 PM
Shell Rotella T6 5W-30 Multi
by kstanf150. 03/19/19 08:21 PM
New Toyota Tacoma oil recommentation
by Moondawg. 03/19/19 08:11 PM
Which oil for modified turbo engine?
by headoff93. 03/19/19 08:02 PM
Saxman657, Maxxforce, Washoe_Mark, CG_BrianM, TBF
67565 Registered Users
90 registered members (3311, ABerns, Back40, arowbat, avi1777, aquariuscsm, 8 invisible), 1,770 guests, and 50 spiders.
Topics286,112
Posts4,902,798
Members67,565
Most Online2,967
Mar 10th, 2019
Page 6 of 9 1 5 6 7 9
Re: hy-per lube zinc replacement additive [Re: DanMiller] #3591241
01/07/15 11:55 AM
01/07/15 11:55 AM
Gone Fishing
John_Conrad Offline
John_Conrad  Offline
Gone Fishing
thanks for posting that vintageant...
since i am learning from the forum, i have some questions regarding that linky above that shows zinc and zddp analysis...
are they not one and the same? or are they different? Is zinc the only value one should look at or look and take both into account?
Because if both values are taken into account then it seems to me there would be too much zinc in the oils than is necessary.
i am not formally edumucated in this field so sorry about all the questions.
Safety doesn't happen by accident.--author unknown
Re: hy-per lube zinc replacement additive [Re: DanMiller] #3591247
01/07/15 12:01 PM
01/07/15 12:01 PM
Gone Fishing
John_Conrad Offline
John_Conrad  Offline
Gone Fishing
ok, so i have reread the article and see that the zddp is calculated and the zinc and phosphorous are from analysis...
so i think that i have answered my own question, and that the zinc value alone is likely the one to use for choosing your oil, but let me know other wise,
thanks
Re: hy-per lube zinc replacement additive [Re: DanMiller] #3591274
01/07/15 12:30 PM
01/07/15 12:30 PM
Florida, USA
vintageant Offline
vintageant  Offline
Florida, USA
John_Conrad
More info here:
http://classiccars.about.com/od/maintena...il-Additive.htm
http://en.wikipedia.org/wiki/Zinc_dithiophosphate
'Classic Cars' probably means pre-1980s and pre-catalytic converters
1925 Alvis HDEO 15W40
1937 Alvis Speed 25 20W50 w LM MoS2 & LM MOS
1970 VW Peking - Paris Rally Beetle HDEO 15W40 w LM MoS2
1987 Porsche 924S HDEO 15W40
Re: hy-per lube zinc replacement additive [Re: DanMiller] #3591347
01/07/15 01:39 PM
01/07/15 01:39 PM
Gone Fishing
John_Conrad Offline
John_Conrad  Offline
Gone Fishing
thanks, i had found the first linky via search...and its a good read for rookies like me!!!
and I do have one of those older vehicles pre1980, in the form of 1978 chevy truck, i am slowly restoring. it has the 400 engine and came from the factory with heavy duty emissions ie no catalytic converter, therefore my interest in this thread.
thank you again sir.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #3591562
01/07/15 04:30 PM
01/07/15 04:30 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
The http://www.hyperlube.com/c3/Zinc-Replacement-Additive-c7.html
is a no-zinc formula for extra anti-wear capabilities that replaces zinc for vehicles in which higher ZDDP levels may affect the catalytic converter.
http://www.hyperlube.com/c3/Oil-Supplement-c6.html is an oil thickener for engines that may have oil loss and bad rings, i.e., an engine that is "loosy-goosy."
All you need in an older engine is a good modern oil of the proper viscosity. For a 400, we run a 10W30 or a 10W40, depending on whether it is a "parade" car or whether it is tracked, respectively.
Has this engine been rebuilt or did you receive it with high mileage?
"I can't change the direction of the wind, but I can adjust my sails to always reach my destination." Jimmy Dean
Re: hy-per lube zinc replacement additive [Re: DanMiller] #3592479
01/08/15 09:59 AM
01/08/15 09:59 AM
Gone Fishing
John_Conrad Offline
John_Conrad  Offline
Gone Fishing
Thanks molakule for the info.
the 400 has been rebuilt
Re: hy-per lube zinc replacement additive [Re: John_Conrad] #3592957
01/08/15 05:03 PM
01/08/15 05:03 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
Then my suggestion is to run Amsoil Break-In oil
http://www.amsoil.com/shop/by-product/motor-oil/gasoline/break-in-oil-(sae-30)/?code=BRKQT-EA
for 500 miles and then change to a good 10W40 mineral oil like PYB or Mobil 5000, unless modern seals have been installed and if that is the case you could run a Blend or even synthetic
For the type of driving it will see, I don't see synthetic as an economic lube.
Re: hy-per lube zinc replacement additive [Re: spasm3] #3594794
01/10/15 08:22 AM
01/10/15 08:22 AM
out there
spasm3 Offline
spasm3  Offline
out there
Originally Posted By: spasm3
Originally Posted By: MolaKule
Being a polymer ester it is very miscible which means goes into suspension and stays there.
It does not appreciably affect the oil's viscosity at cold temps.
Here is a way to show yourself this works. Put about 2.5 oz. of Hyperlube in a quart of 5W30 oil. Bring it inside and mix it. Set it ouside and compare it to a non-additized quart of 5W30 oil, same manf.
Tell us what you see.
I may try this. I have some gsud in clear bottles. Now i know that in older posts you have suggested that with schaeffers 132, you only need 5 or so ounces as an antiwear. How much of this is necessary? They suggest a quart with 4-5 quarts.
I tried this, i cant see any obvious viscosity by shaking etc. IT appeared the air bubbles moved the same when shaken, i can't see a difference. What did i miss? Or is that the point?
13 elantra 75k 5w30 QSUD
03 chevy avalanche 80k synpwr 5w30
17 mazda cx-5 9500 miles m1 0w30
Re: hy-per lube zinc replacement additive [Re: DanMiller] #3595180
01/10/15 01:52 PM
01/10/15 01:52 PM
out there
spasm3 Offline
spasm3  Offline
out there
I put both bottles in the freezer to -8 degrees f. Still i see no difference in how the oil moves , holds bubbles or how the oil film moves back down the bottle.
Re: hy-per lube zinc replacement additive [Re: spasm3] #3595233
01/10/15 02:54 PM
01/10/15 02:54 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
Did you mix the HyperLube Zinc replacement with QSUD and then put it in a freezer?
You lost me in your sequence of events and what you used.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #3595244
01/10/15 03:12 PM
01/10/15 03:12 PM
California
CrawfishTails Offline
California
Would the HyperLube Zinc-replacement stuff compete with the other AW additives in a fully formulated oil (i.e., Mobil1)? I noticed some researchers said you can't just add Ionic Lubricants (ILs) to fully formulated motor oil, as it competes for the surface with what normal motor oils already have. Can we assume Hyperlube is not going to work based on the experience with IL ?
Re: hy-per lube zinc replacement additive [Re: MolaKule] #3595361
01/10/15 04:56 PM
01/10/15 04:56 PM
out there
spasm3 Offline
spasm3  Offline
out there
I took a bottle of qsud and took out 2.5 oz of oil, added 2.5 of the zinc replacement. I shook it well , no noticeable difference. I set it on my porch overnight with another unopened bottle of gsud (20f overnight. I could not see a real difference, so i then put both bottles in the freezer for several hours at say -8. I took them out, shook them looked at how the oil moved, ran down the neck of the bottle, looked at how the air bubbles moved through the cold oil when shaken. Not sure what i should have seen but i could not really tell a difference. Did i use enough of the additive? This oil is going in my saturn tomorrow btw.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #3595477
01/10/15 06:44 PM
01/10/15 06:44 PM
out there
spasm3 Offline
spasm3  Offline
out there
Would this test be better with a conventional oil rather than a synthetic?
Re: hy-per lube zinc replacement additive [Re: CrawfishTails] #3595611
01/10/15 08:37 PM
01/10/15 08:37 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
The HyperLube in question is not an Ionic Liquid and does not compete with other AW additives but is synergistic.
Re: hy-per lube zinc replacement additive [Re: spasm3] #3595617
01/10/15 08:39 PM
01/10/15 08:39 PM
Iowegia - USA
MolaKule Offline
Global Moderator
MolaKule  Offline
Global Moderator
Iowegia - USA
Okay, gotcha.
You should see little difference between the unadditized oil and the additized oil in terms of low temp viscosity, which appears to prove what I said earlier.
It should not matter.
