CV Joint Leaking Grease
by 92saturnsl2 - 08/22/19 10:20 PM
Craftsman 6 pc. Screwdriver Set $12.14
by Warstud - 08/22/19 09:32 PM
Got My ATF Replaced.
by Mr_Luke - 08/22/19 09:20 PM
Wht do people with labor intensive jobs lay on their back?
by motor_oil_madman - 08/22/19 09:14 PM
Date code 5 Q Chevron location?
by Onetor - 08/22/19 08:06 PM
Confused, what oil to use?
by BelAir - 08/22/19 08:00 PM
2015 KIA optima turbo Coolant Flush
by Grambo - 08/22/19 07:52 PM
Motul 300V -- oops
by xr650boy - 08/22/19 06:35 PM
Evolution of Garbage Trucks...joke thread
by GumbyJarvis - 08/22/19 05:57 PM
What is this Oil's Application?
by MolaKule - 08/22/19 05:19 PM
Ford 2.5L Engine and 6F35 Transmission
by drh214 - 08/22/19 04:57 PM
Fram XG7317 vs XG3593A
by gamefoo21 - 08/22/19 03:59 PM
Carquest premium 85334
by SlavaB - 08/22/19 03:47 PM
Oil for a Ford 2.8 L Cologne V6
by ford4wd08 - 08/22/19 03:46 PM
Good Question?🤔
by Mad_Hatter - 08/22/19 01:40 PM
Autozone misinformation?
by NavyVet88 - 08/22/19 11:23 AM
Did I mess up getting a civic that sat?
by Kurtatron - 08/22/19 10:48 AM
What are these two things in the bumper?
by atikovi - 08/22/19 09:48 AM
Amsoil Metal Protector
by Snagglefoot - 08/22/19 09:07 AM
PTL, vdubw, NJ01MGM, Antiquity, tundraotto
69034 Registered Users
26 registered members (Deontologist, carlprop, e55amgbenz007, edyvw, clinebarger, 4 invisible), 881 guests, and 20 spiders.
Topics293,664
Posts5,044,641
Members69,034
Most Online3,532
Jul 30th, 2019
Page 4 of 9 1 3 4 5 9
Re: hy-per lube zinc replacement additive [Re: MolaKule] #2791846 11/03/12 02:52 PM
dailydriver Offline
Originally Posted By: MolaKule
Quote:
There is one oil mfg that's using these esters with PAO and has no ZDDP whatsoever.
Quote:
So that nameless company is using something similar to this additive to eliminate the use of a different anti-wear compound.
It is no secret.
Do a search on "FUCHS."
Mola; is this what is in their Titan GT1 XTL 0W-20 brew??
2016 Ford Fiesta ST 17K miles
Ravenol REP 5W-30
Fram XG3600 filter
Ravenol MTF-2 in the IB6 transaxle
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2791870 11/03/12 03:14 PM
MolaKule Offline
Global Moderator
Global Moderator
Let's just say FUCH's and AK have had a long history of cooperation.
The value of a scientific theory is its ability to prompt further study, not that it has any relation to the established facts of scientific reality.
Re: hy-per lube zinc replacement additive [Re: MolaKule] #2792044 11/03/12 05:36 PM
DanMiller Offline OP
Who / what is AK ?
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2792225 11/03/12 09:10 PM
L
Loobed Offline
L
I am guessing that this stuff wouldn't be good for motorcycles with wet clutches.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2793880 11/05/12 06:28 PM
dailydriver Offline
Originally Posted By: DanMiller
Who / what is AK ?
AKZO chemical company, the producers/marketers of Ket Jen Lube polymetric ester products.
Ravenol REP 5W-30
Fram XG3600 filter
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2805909 11/17/12 10:57 PM
L
Loobed Offline
L
I was looking at the hyper-lube zinc replacement MSDS, and it says that the freezing point is <-20C (-4F).
What happens if this stuff is mixed with regular 5w-30 oil when the temperatures drop below the freezing point? Does it stay in suspension, rise to the surface, sink to the bottom, or something else? Could it plug up the oil screen? I would think that once it gets to the oil pump gears, the mechanical force of the gears would raise the oil above its freezing point.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2812856 11/24/12 07:49 PM
MolaKule Offline
Global Moderator
Global Moderator
Being a polymer ester it is very miscible which means goes into suspension and stays there.
It does not appreciably affect the oil's viscosity at cold temps.
Here is a way to show yourself this works. Put about 2.5 oz. of Hyperlube in a quart of 5W30 oil. Bring it inside and mix it. Set it ouside and compare it to a non-additized quart of 5W30 oil, same manf.
Tell us what you see.
Re: hy-per lube zinc replacement additive [Re: DanMiller] #2814681 11/26/12 01:03 PM
dailydriver Offline
I wonder what is the actual VI of this stuff??
Ravenol REP 5W-30
Fram XG3600 filter
Re: hy-per lube zinc replacement additive [Re: DanMiller] #3587153 01/03/15 06:15 PM
J
JR Offline
J
1pt in with 3qts M1 0w-20EP in thee geo the last service.
ken
97 F250HD 7.3 320K 01 Astro 220K
93 metroXFi 94.5K
01 Impala 300K
04 RTV900R 1150hrs
Re: hy-per lube zinc replacement additive [Re: DanMiller] #3587599 01/04/15 04:14 AM
Clevy Offline
I just re-read this thread. I'm significantly more interested in this stuff.
2006 Charger RT
Miles x 2 per oil filter
Re: hy-per lube zinc replacement additive [Re: Clevy] #3587638 01/04/15 05:57 AM
T
Turk Offline
T
Yes, I just re-read it myself. May use this or Lubegard next time.
When I put LubeGard BioTech in my new to me Saturn SC2 with 156,000 miles, I noticed a definitive "freeing up" of the engine. It's hard to explain, but it was almost like revving up the engine in Neutral vs revving it up in gear, if you know what I mean??
03 GMC Sierra 4x4 200k M1 0-40+PU
00 Saturn SL2 89 YO Lady Car 92k, Edge Ext
98 Saturn SC2 Rare "Red Hot" 165k, Edge Ext
97 Camry 245k, Maxlife
Re: hy-per lube zinc replacement additive [Re: DanMiller] #3587740 01/04/15 09:09 AM
R
rockydee Offline
R
I used it in few flat tappet engines, I used the Red-line BI add too. Both seemed OK, RL was easier for me to get though.-RD
Re: hy-per lube zinc replacement additive [Re: DanMiller] #3588462 01/04/15 08:54 PM
dailydriver Offline
^^^Yes, this product has disappeared from the shelf at Pep Boyzz, but it is still on the Vato Zone shelves.
Ravenol REP 5W-30
Fram XG3600 filter
Re: hy-per lube zinc replacement additive [Re: dailydriver] #3588588 01/04/15 10:26 PM
MolaKule Offline
Global Moderator
Global Moderator
It's about 229.
Re: hy-per lube zinc replacement additive [Re: MolaKule] #3588599 01/04/15 10:35 PM
spasm3 Online Happy
Online Happy
I may try this. I have some gsud in clear bottles. Now i know that in older posts you have suggested that with schaeffers 132, you only need 5 or so ounces as an antiwear. How much of this is necessary? They suggest a quart with 4-5 quarts.
13 elantra 78k 5w30 synpwr
17 mazda cx-5 12300 miles m1 0w30
