Yeah, and dishwashing soap would probably do better than any of those ... guess I'll go dump some dishwashing soap in my crankcase ...quote:
Originally posted by Jelly:
Just watch the videos on their website...then you'll believe in it!
http://motorkote.com/demo1.htm
http://motorkote.com/demo2.htm
Geez. I'll tell ya, I'm fast reaching the point that if a product is tested and "substantiated" via anything that involves weights, a lever, and a wear scar, I'm going to run screaming hysterically in the opposite direction.quote:
Originally posted by salsahh:
Your kidding me right? Motorkotes tests are funnier than the ones done on lucas. SFR would knock the snot out of motorkote any place any time they only put like maybe 7-10 weights on that machine I've seen tests with SFR with an extended arm and someone holding the motordown pull 40 weights with a wear scar less or the same. There are far better products out there than Motorkote when ever any one hears its the best product on the market it makes everyone think of ways to discredit the product. All of motorkotes hoop la about FTC and what knot is played out amsoil whipped that dead horse a long time ago. Lets get to the root of things WHY or WHAT is the or makes a GREAT product.
Well logically there would appear to be a cooralation, both are wear between metal surfaces. And maybe that's why they use it.quote:
Originally posted by crashz:
Has there ever been any concrete evidence that the wear scar tests prove anything in regards to lubrication protection? Like has an oil or additive that scores high (small wear scar) proven itself by dramatically (or even slightly) improving engine life and efficiency over comparibale products over many miles on many different engines.
Or is it just the quick marketing gimmick that it appears to be?
I stand corrected in that Frank never worked on Motorkote, but developed MTX.quote:
Originally posted by Frank:
I helped develop "MTX" a better long chain chlorinated friction reducer than what was on the market than. I know Dr. Dave
and have never been involved with Motorkote.
