I removed mine to remove surface rust and repaint it. 6 bolts, 5 minutes max.
I drove my top heavy Van today without it.
If Somebody else had removed it unknown to me, I don't know if I would have known the difference.
I even drove it more aggressively than normal, around some traffic circles and could detect only minimal more lean than normal, and that might be cause I was expecting it.
I guess I should state that I do have stiffer springs up front than stock, and rear air bags(slightly above minimum PSI), but I've been used to those for years.
If anything, Hitting a pothole with only one tire was smoother than it would have been with the Stabilizer.
I am almost considering carrying 35 lbs less around, and leave it off.
