Originally Posted By: Greggy_D
My question is.....does MMO clean the ring packs and is it verifiable?
This is one of ARx's "claim to fame".
(Not advocating one product over the other)
I posted this a while back, here it is again FWIW.
Vintage 1970's Chevy 250 I-6 engine, which is worked hard. My brother ran a compression test over the winter, 5 of the 6 cylinders were reading ~ 150 lbs, cyl #4 was at 130, we had a slight miss at idle, plenty of power when running.
Fast forward to the beginning of the season. PYB straight 30 grade, 1 qt MMO, the miss got worse, we said screw it the engine is old we'll run it till we can get another engine. We ran the PYB MMO combo for 50 hours. Then my brother gets the bug to look further into it so we ran the compression test again. Much to our surprise the compression ranged from 150-152 lb per cylinder across the board. The weak cylinder came back to life.
The miss is still bad though? This engine uses a special intake exhaust manifold that looks like a big log and is a once piece unit. We went through everything, carb, points, plugs timing, and noticed each time it missed the vacuum gauge would pulse. So we decided maybe it is that intake/exhaust manifold gasket? We changed it and are pretty certain it was leaking exhaust into the intake.
Confusing? Yes, the boat is running perfect now!
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1941533
