Its a scam for dealers to pad their bottom line, no advantage to daily drivers. If the air we breath is 75% nitrogen how do they get all the air out of the tires so they can get in 100% nitrogen? evacuate all the air and the tire might collapse? and if there is nitrogen in the tire how do you test it if the tire does have all nitrogen. They just put a green cap on the valve stem and send you away, Google nitrogen in tires, now don't get me started on body and window etching...just fill it with air and forget about it...
