Good afternoon guys.
I was wondering if dropping the transmission pan on the 4L65E transmission in my 2008 Chevrolet Impala (has 54,xxx and has never had the fluid changed) and changing the fluid/filter would be sufficient or would you recommend doing a complete flush using the cooler return line? And are there any risks on running the transmission dry for a couple of seconds before shutting the engine off while flushing?
I bought 8 quarts of Valvoline Dextron VI, which is supposedly full synthetic. I was told the initial fill was 7.39 qts. Any idea on how much fluid I can expect with a simple pan drop and filter change?
And is the full synthetic Valvoline Dextron VI really any different from the AC Delco or Castrol syn-blends if they all have to meet the Dextron VI specifications?
Thanks in advance for any advice/information,
Gary
Gary
