Originally Posted By: Tucson Five-O
Sorry for the confusion. When I said flush I meant I would disconnect the return line (which one would that be? I know it's the cooler of the two and does it have to be that one?) put a section of clear vinyl hose over it and drain into a bucket with the engine running until I see some air pockets appearing.
This would be my preference but it scares the you-know-what out of me. I'm worried about damaging the transmission. And is there a fill plug or do I refill through the dipstick? To be honest I haven't checked to see if this car has a dipstick. I'm not as anal with the transmission as the engine but that's going to change.
Thanks,
Gary
No problem i hear ya..
if unsure what line is what just put a hose on both stick in bucket and start engine once you see what line you need shut off engine and use that line,i'll tell ya over the many years of doing the line flush i run the engine till the oil stops flowing then a few seconds after that,NEVER a transmission problem.
Do your pan and filter change once buttoned back up fill trans with say 8 qts or half of factory spec.
have hose in a qt bottle have a helper start the engine once the qt is full stop the engine,pour 1 new qt into the trans,repeat above have helper start car when qt bottle is full stop engine add 1 qt back,do this for 4-5 qts and watch the oil get cleaner every time coming out.
if you have the dipstick less trans you'll need a funnel to get to the fill hole,usually a red cap on the trans driver side top.
Thanks,
Gary
