AME 37330 Hub Cleaner for Impact Wrench
by The Critic - 11/18/19 01:54 AM
Plastic bag vs Car
by The Critic - 11/18/19 01:50 AM
Fram XG7317 20k miles cut open
by dbeau - 11/17/19 09:46 PM
2021 Ford Mach-E Electric SUV
by KeithS_NW_Ohio - 11/17/19 09:05 PM
Walker mower Oil
by Joey737 - 11/17/19 09:03 PM
Rough service tough light bulb 1¬Ę at Home Depot
by JLawrence08648 - 11/17/19 08:40 PM
2015 F150 5.0 8592 miles
by Buzzinhalfdozen - 11/17/19 08:36 PM
MOPAR MO-285 FACTORY OIL FILTER CUT OPEN
by 53' Stude - 11/17/19 07:43 PM
Best Garage Door Seals
by Gebo - 11/17/19 07:18 PM
Bar oil as fogging oil
by WA1DH - 11/17/19 06:47 PM
Fram PH2 ExtraGuard Cut Open
by A310 - 11/17/19 06:38 PM
C&P Pentius UFXL PH16-equiv.
by 92saturnsl2 - 11/17/19 06:18 PM
Fleetguard WF2074 Coolant Filter Cut Open
by Pyrotechnic - 11/17/19 05:24 PM
Cuts on tire sidewall
by mclasser - 11/17/19 03:19 PM
Hyundai Theta II Engine in Newer Years
by smc733 - 11/17/19 02:41 PM
Walmart deals
by Deere John - 11/17/19 02:33 PM
Grumpy Kid
by wings&wheels - 11/17/19 01:57 PM
h9/95R FLA Batteries
by TXCarGeek - 11/17/19 01:40 PM
Preventative parking brake service
by Donald - 11/17/19 01:26 PM
JimBobSeeker, Joey737, bdavis218, XTR74, 2009Caraman
69899 Registered Users
28 registered members (carlprop, AndyB, CharlieBauer, cjolson140, BrandonT, 4 invisible), 796 guests, and 18 spiders.
Topics297,569
Posts5,118,190
Members69,899
Most Online3,589
Nov 2nd, 2019
Motor Oil Suggestion: 2001 Honda Prelude #1896490 05/19/10 03:46 PM
X
xiayu Offline OP
X
I'm looking for suggestions for a synthetic oil to switch to. Iím also wondering if I should first switch to a synthetic blend before moving over to full synthetic. Right now I'm thinking about Mobil 1 0w-30 full synthetic.
Make: Honda
Model: Prelude
Year: 2001
Engine: H22A4 (2.2 liter inline 4 cylinder)
Oil: Chevron 5w-30 (API SM, I believe, petroleum-based motor oil)
Filter: PH-3593A (Fram oil filter)
Miles: 98,000
I'm unsure about certifications that the owner's manual calls for. I've tried to find an online manual but not much luck; I'll have to dig up my manual. I would imagine itís SL since this model was around from 1997-2001.
As far as driving style goes I've been taking it pretty easy lately. Every once in a while other drivers make me push my car as hard as it will go (red lining every shift, which is 7500rpm I believe) but I don't do that too often these days. I drive anywhere from 20 to 100 miles a day, at least 50% of which is on the freeway and at most like 90%.
Currently I'm using a petroleum-based motor oil so I've been changing it every 3000 miles. I just went back to 5w-30 from 10w-30. I had been using 10w-30 although the manual says to use 5w-30 because for a while my car seemed to be burning oil and when I tried 10w-30 the oil consumption and black soot on my rear bumper seemed to go away. Now that I've read more about how motor oil works I really doubt that was what happened and I'm leaning towards switching to a 0w-30 synthetic now. Another reason that I am using petroleum-based motor oil for the moment is that it is much cheaper and I just did a Sea Foam before the last oil change. I followed the directions so 1/3 of the bottle went directly into the crankcase and I changed the oil 300 miles later. I just changed my oil again 3000 miles later and my next change I would like to switch to a synthetic for all the reasons anyone would switch to synthetic.
Re: Motor Oil Suggestion: 2001 Honda Prelude [Re: xiayu] #1896531 05/19/10 04:05 PM
B
Boss302fan Offline
B
I would try a couple of OCI's of 3K miles with 10W30 Maxlife high mileage blend before going to a full syn. It is highly thought of here and will also do a nice job cleaning up your engine. Actually, I think you should just use this oil all the time and not switch over to a full syn. Great oil and you can find it at Walmart for around $15 for 5 quarts.
The Chevron you use is a really nice conventional oil.
John P
Wisconsin
2018 Subaru Outback 3.6R Limited
2006 GS 430
2006 Lexus LS 430
1990 Jaguar XJS V12
2011 Hyundai Santa Fe V6
Other fun cars
Re: Motor Oil Suggestion: 2001 Honda Prelude [Re: Boss302fan] #1896547 05/19/10 04:13 PM
P
pbm Offline
P
My 2001 Accord calls for SJ rated 5w20 oil in the owners manual. I've used 0W20,5W20,0W30,5W30,and 10W30 and all work well. I do feel the engine revs a bit freer on the 20 wt. but its barely noticeable (and may be my imagination.)
The Chevron 5W30 that you are using is on the thinner side of the 5W30's and is a good choice, IMO. I'd stick with it for 5K OCI's.
'Journalism is Dead'
Re: Motor Oil Suggestion: 2001 Honda Prelude [Re: pbm] #1896614 05/19/10 05:09 PM
calvinnnnnnnnn Offline
use whats been working.
maxlife 10w-30 or synpower 10w-30 is what i'll use for the summer
Re: Motor Oil Suggestion: 2001 Honda Prelude [Re: calvinnnnnnnnn] #1897489 05/20/10 11:37 AM
R
ryan2022 Offline
R
Use something on the thick side of a 30 weight.
If youre thinking 0w30, id shoot for GC. The H22 is a great engine, but loves to burn oil, mainly by design.
2011 Subaru Impreza Hatchback 5w30 Mobil 1
2015 Subaru Outback 2.5 Limited 0w20 Mobil 1 AFE
1995 Nishiki Navajo mountain bike....some kind of chain oil.
Re: Motor Oil Suggestion: 2001 Honda Prelude [Re: ryan2022] #1897507 05/20/10 11:49 AM
A
addyguy Offline
A
The 2.2 engines used in the Preludes used ceramic bore liners that wear badly, and most of these preludes burn a lot of oil.
The engine isn't really hard on oil, so just make sure it is kept topped-up, and you should be good. You can also move your OCI up to 5-6k w/o worry.....
2010 Kia Soul 2U - 2.0L I-4, auto; 148k miles.
Castrol GTX HM 5W-30, STP blue bottle; Fram TG 9688.
2009 Pontiac G5 - 2.2 I-4, auto, 121k miles.
Oil/filter TBD
Re: Motor Oil Suggestion: 2001 Honda Prelude [Re: addyguy] #1897570 05/20/10 12:49 PM
drfeelgood Offline
I've owned my Prelude VTEC since 1996 and have tried lots of diff. oils and filters.
It has definitely been smoothest and run the best on Maxlife 5-30 and Schaeffers 9000 5-30.
These engines do use some oil. Agree with keeping topped up.
Also, GC may run smoothly, but I think was a bit thick for this engine.
2008 Z06
2005 Z51
2002 M5
2017 Charger SRT
1996 Prelude VTEC
1969 Mustang 428CJ
1970 Chevelle SS396
2010 Commander Hemi
2009 Escape Hybrid
2010 Cube
Re: Motor Oil Suggestion: 2001 Honda Prelude [Re: drfeelgood] #1897597 05/20/10 01:20 PM
M
Mau Offline
M
The h22 is known oil consumer. Stay off the vtec if you want to reduce oil consumption.
I have tried GC 0W30, Amsoil ASL 5w30 and PP 5w30. I found PP to be the best, I think Amsoil was good too but it was pricey and a bit of a pain in the [censored] to get as well I didn't like the 1L bottles.
PP comes in 4.4L or 4.73L container (so I can dispose of my old oil), car runs dandy with it. I burn about a quarter of a qt for my 6000 km oil change interval using Wix or Bosch Premium filter.
0W30 was ok but I found it heavy and again only available in 1L bottles.
I check up on my oil every 2 weeks, I think I am getting rid of more oil by checking it every 2 weeks lol.
17 MB C43 AMG - Pennzoil Platinum Euro 5w40
Re: Motor Oil Suggestion: 2001 Honda Prelude [Re: Mau] #1897632 05/20/10 01:57 PM
A
Andyge Offline
A
I think I would use 5w-30 PYB or MC5K.
I ran 5w-30 PYB in my 99 CIVIC EX for many years and sold it last year.
Andy
