Cracked Coolant Expansion Tank on Ford Taurus
Michigan
I was having problems on my 2001 Taurus with 124,000 miles with losing coolant but not seeing a obvious leak anywhere. I could at times smell the coolant but its source was hard to find. I finally took it in and they found the bottom of the coolant tank had a small crack in it. Since these are pressurized it would leak a little when warmed up.
I was told this is a common problem with the Taurus Coolant tanks. I called around to junk yards and they told me the same thing. They checked a few they had and they were bad also. Another junk yard had new ones. He said he buys 12 at a time because he gets so many calls! The dealer wanted like 80.00 for them and he wanted 44.00 for the ones he had. It works great!
That's funny, the junkyard selling new parts!
Keep 'er flushed, the radiators are not much fun on these cars.
Coolant recovery tanks are not pressurized.
Edited to add:
MOST coolant recovery tanks aren't pressurized.
Some are; those with pressure caps on them are under
pressure. The heat from expanding coolant could open a
crack that won't leak if cold/cool.
On many new cars they are. The pressurized cap is on a surge tank which acts as the recovery tank.
We used to have a plastic welder at the shop, but it was very tricky to use.
Kinda like a heat gun with plastic welding rods.
A new tank is best.
Many coolant expansion tanks of first generation LS400 have small cracks at the top around temperature connector. It is expensive, dealer wants more than $200 for a small plastic tank, a used one can fetch $100 or more on Ebay.
I think pressurized coolant expansion tank is a bad idea, coolant reservoir is safer and more reliable.
Ford calls them a degas bottle and almost all of the newer vehicles have the pressurized degas bottle, which acts as a coolant recovery tank.
Your mean the "coolant expansion tank."
Looking forward to a skirmish over semantics.
quote=oilyriser]I call it the coolant freshening tank, because it leaks just enough to keep you adding enough coolant so you never need to change it.[/quote]
Or the fish/egg stream killing leak.........
The expansion tanks sure make it easy to bleed out the air.
