Lots of Zmax threads here on it. Search engine is your friend.
BTW, I could care less about Indy500 race engines and claims to hype up the additive. Its kind of meaningless for a daily driver.
I'm 5500 miles into a 7500 mile sponsored run with Zmax. 2000 more miles(another month of driving) and I will post a sponsored UOA of it. MPG/power/feel/sound... has been the same or similar. So, the only guide I will have is the UOA data with it, and over the next year, the follow-up UOAs without it. Engine#1 is 2 years old with about ~48k miles with overly frequent full synthetic oil changes always.
I have a 2nd vehicle, non-sponsored, that will also see a UOA with it. It will have about 6k miles and is on a yearly OCI. So, we'll see the 2nd vehicle, for comparison, probably in 10 months, and 2 years from now with the non-Zmax follow-up fill UOA. MPG has improved on 2nd vehicle. And, the 1st road trip after the OCI that added Zmax, the engine developed a burping/splurging/bubbling fluid/air noise for a few minutes. Scared the [censored] out of me but filter was on tight, no double gasket, and oil level was perfect. It went away. With the MPG improvement, and the weird gurgling sound that I got, I can surmise, but not prove, that the VVT is now working 'more properly'. Engine #2 is on a 8-10 month OCI with synthetic always(7 years old ~60k miles).
No feelings changed in engine#2 with Zmax as the FI cleaner. Engine#2 always ran smooth, started easy, never lacked power... and FI cleaner was just a normal OCI regimen as PM.
I'm contemplating to send in a sample for a SAE J300 battery of tests to see how good of a base-oil it is. Not enough sponsors yet!
And, as an FI cleaner, I still haven't developed my 5k miss on engine #1. Usually I get a cold start hiccup or idle hiccup, even when using toptier fuels, that is always cured with an FI cleaner like Techron, 3m, SI1, Lucas, or... and repeats itself again by 5k miles. So, it either cleaned well or coated(soaked in) that pesky injector. Time will tell.
The term "micro-lubricant" is a term that I don't care for. Its just the registered trademark. Means nothing.
And, for ANYONE that has some crud, varnish, or sludge, scrape it off and mix it with a few drops of Zmax and judge for yourself. I will surmise that it is a high-end base oil with great cleaning abilities and performance, maybe similar to Chevron's Isosyn technology.
There were a couple UOAs here. Might want to search the UOA section here or online. The UOA showed that Zmax DOES thin the oil a little. So, if you get a tad bit of power or MPG, you could possibly do the same by selecting a thinner oil.
For the generic Zmax MSDS, no info can be assumed. I want to believed that Zmax is a higher-end group III/III+ base with some type of proprietary finishing or treatment. Or, it could be the greatest scam out there. You can get a gallon of high end group 4/5/6 base oil for what they sell this little Zmax bottle for.
Some good articles on base oils here:
http://www.chevron.com/products/sitelets/refiningtechnology/clg_articles.aspx
And the iso-links here:
http://www.chevron.com/products/sitelets/refiningtechnology/iso_cat4a.aspx
