YMMV Mobil 1 European 5w-40 5 qt 3 pack $24.47 at select Walmart stores
What exactly did you ask customer service. Did you tell them you ordered a six pack and received a single?
That's what I started with, but they easily get confused. I said:
"I ordered 4x multipack, but received 4x single pack", to which they asked:
"So how many pieces did you receive vs ordered?", and when I said I got 4 instead of 24, then they jumped to their script about Quantity, signature on delivery, process a chargeback...
So I followed up with "Can't I just try to return to the local WM and process a return?" , and they were unsure and just said I could try but they mask ask for the ordered Qty back (which you and I know, likely is still 4 SKUs of a single unit).
So I'll go ahead and start the return online and if it craps the bed at the local store, I'll just keep 'em and start a chargeback.
1 of 2 boxes delayed
It's been a couple years, but they will take them back no problem. It will ring up as a SKU for 1 jug, just as they got picked.
The M1 5w40 thing was an anomaly. A wise person in here stated that it worked because that was a true "Case of 3." Not a description error of Pack of 3,6,9,12, etc.
Edit: hat tip goes to @AKhan87 from Konvict Muzik
The thread title says
Mobil 1 European 5w-40 5 qt 3 pack $24.47 at select Walmart stores.​
Not, I bought 6 packs or 12 packs of vaporware that is an obvious and known price error.​
So I am now 2 of 4.
Most recent that worked said "pack of 3" and showed a box.
An earlier one that worked said multipack qty 3 and showed 3 jugs in the picture
The two that did not work used similar wording, but showed only one bottle.
I am not going to say its definitive - but that was my experience so far.
