I have a 2015 RX350 that I bought in August 2021 with 160k miles on it. It currently has 228k miles on it.
It has had ONE repair in those 228k miles - some oil sensor for the VVT operation. Can't remember the exact part. The previous owner had it replaced at a Lexus Dealer at about 150k miles.
As you can see, we will probably put about 80k miles on it by it's 3rd year of our ownership. Here's what I have done to it:
Oil & Filter changes
Trans pan drop, filter, clean pan, new gasket and refill with Amsoil OE Trans fluid (will repeat soon)
Drain and fill trans fluid
Rear brakes 1x with Lexus OEM pads and Rotors
Front brakes 2x pads, 3x rotors. First time I used the Powerstop OE pad/rotor kit. Vibrations were very present after 40k miles. I had the old rotors turned and replaced them. First time I stupidly used the purple Permatex brake grease and it had caked up solid. I cleaned all of that out and used SylGlyde. When I say cleaned it out, I take the pad bracket, take the boots off, fill the cylinders up with brake clean and let it soak. I use Q-tips and rolled up paper towels to dig down and get all the boogers out. Those turned rotors lasted about 20k miles... I ordered up all OEM stuff, which is about $20 more than cheap Powerstop stuff and did it all over again. Been smooth sailing since.
Flushed brake lines when doing brakes
Drain and fill coolant (need to repeat soon)
Replaced rear hatch struts
Replaced hood struts
Air/Cabin air filters
Spark plugs at 162k miles
Cleaned throttle body at 210k miles (this should be done at spark plug replacement)
PCV Valve (162k miles)
When I bought it, it had a brand new set of Khumo tires on it. They were rated for 40k miles. I think I got 42k out of them. It now has a set of Michelin X-LT ("LTX M-S") on them, rated for 70k miles. They have have 26k miles on them and look great, ride smooth, etc.
I have a set of OEM shocks and struts laying in the garage floor. I need to get them put on soon.
It needs the sunroof motor looked at. I have the fused pulled for the sunroof so someone doesn't accidentally open it. It needs the rear hatch motor replaced. It still opens manually just fine. The motor is about $350 and this is a fairly difficult DIY job.
It goes from point A to point B very well. People do not believe it has nearly 250k miles on it. The inside looks great, the outside does have several pock marks on the hood, some scratches on the sides, etc. It is very tight, quiet and smooth.
I change the oil every 5-6k miles and it's "clean" looking. I generally tear the Toyota OEM oil filter apart, try to look through each pleat. I see 1-3 tiny, tiny specks of aluminum material each time.
I would have zero problems buying another 2015 RX350 that has ~150k miles on it and has some proven maintenance. These things are bulletproof.
Contrast -
A co-worker of my wife - she just had to get rid of a 2018 NX200 with 70k miles on it because the timing chain set was shot. She claims it had been very, very well maintained with oil changes much more often than Toyota recommends. She is still fuming about that and it has damaged their family's opinion of Toyota/Lexus.
