There are several UOAs of mine on here with the old version with tungsten, and it did not fare very well even at just 6.5k OCIs. Also, not all esters (Group V) are created equally- there is no documentation if the esters Ravenol uses are polar, which is what would give you cleaning. Redline oils, which for years were sought for their esters, have been confirmed to be non-polar, and therefore non-cleaning in the way you’re hoping.
There are really only two readily available oils that have been proven to have the two “magic” cleaning compounds, alkylated napthalenes and highly-polar esters, and those are M1 FS 0w40, and the entire HPL line of oils. There is the Valvoline Restore Blue, but that does not carry any gasoline certifications and also is unobtanium. Again, I’m giving you personal results from verified use & analysis, not just shouting down Ravenol.
Best of luck if you’ve already purchased the DXG, but I suspect it will fall short of the high hopes you have for it, just as it did for me.
