Been snowed in a bit lately and have spent more time (than usual) trying to understand oil capacity and demand. Have a few basic questions:
1. When does an engine demand the most oil? I've always assumed it was at high RPMs.
1a. In a typical engine, does a pump send out more oil at, say, 5000 RPM than 4000 or is there a max output that is reached sooner?
2. In a typical engine/pan, what is the greatest percentage of capacity that is ever in use at once? For instance, in a 6 qt. system, how many of those 6 qts. are out "working" and how many are waiting in the pan to be pumped up into action? ( The origin of this question is my friend's Jeep, after his wife ran it for an extended period with only around 3 qts. in the 5.75 qt. system.)
3. Do some engine designs just require more oil to properly lubricate while in operation? I have owned the Jeep 4.0s that have 6 qt. systems, and now a 5.3 GM that also takes 6. The GM engine is about 25 percent bigger yet their manufacturers required the same amount of oil.
Thanks for enlightening me.
