What socket removes this pulley bolt?
Suburban Washington DC
[Linked Image]
06 Wrangler 4.0. T40 torx too loose, T45 won't fit. T40 fit perfect in the tensioner bolt btw. Is there a special socket bit for this?
start by cleaning the crud out of the socket. Try the T 45 again. I use one of those "gimme" shirt pocket screwdrivers to dig road grime out of them so the Torx will bottom out in the socket.
The Torx Plus looks to be able to apply torque better Another screw for robots.Thank you for knowledge. Do 2016 Camrys use them?
Originally Posted by Little_Lebowski
Originally Posted by slacktide_bitog
Originally Posted by Linctex
Just replace the whole tensioner assembly.
YES, really.
THIS
Speaking from experience, THIS
The spring in the tensioner isn't making noise. Actually the pulley bearing isn't either but I feel looseness. $14 vs. $45. It's a 76,000 mile truck. If it was 150,000 miles I would.
Originally Posted by atikovi
After a search, I think it's Torx Plus.
To me, it looks more like a Polydrive. If you look close you can see that the lobes are squared off and are not tapered like they are on a Torx Plus socket.
