Originally Posted By: oil_film_movies
Originally Posted By: Shannow
statement was that synthetic is wax free...that's false.
Syn is
way lower on waxes.
statement was the synthetic "flowed" better at
-5C...that's false.
It was
-5F, not C, which is -20C. I thought that would be cold enough to see some differences between GroupII conventional and GroupIII syn. Years ago I left a small assortment of dino and syn oils outside to 0F overnight, and I seem to remember the syn was less (low-shear) viscous anyway. "Mo' liquidy" is the tech term for it.
Bottom line, we have been programmed to believe that faster cranking and less viscous oil from a 0w20 is better for engines than anything else. It has always sounded
reasonable to me, especially at -20C (-5F).
Until somebody has proof that
thicker cold oil is
better for an engine, I'll cling to my belief that less viscous oil gets to parts quicker on cold starts.
"The easier and quicker oil flow also promotes faster lubrication of internal engine parts when the engine does start. " --- Lycoming Engines engineering recommendations,
https://www.lycoming.com/content/operating-cold-weather
Apologies, that was a typo through force of habit...
Your request to post that thicker oil is "better" for an engine is a strawman...so I won't bother....however, as most of the wear is during the warmup phase, as the oil is thinning and the additives are getting their act together, maybe thicker holds a slight advantage in wear in that regime...Not economy, which is the reason de extreme for a few of the grades (by the OEM's own admissions).
Per the "flows faster", I'll just copy some stuff I posted in another thread...same premise as this, same usual suspects with the same statements...
https://bobistheoilguy.com/forums/ubbthreads.php/topics/4601794/1
Originally Posted By: Virtus_Probi
I doubt the two are going to be very different at 0F, although I think Shannow has showed some great curves in the past that gave some real numbers for the two across a wide temp range (and were probably killed by the Photobucket change since then).
I've found a new set, and will try to get some off photobucket when I've got time...
This one was good, in that it showed how a bunch of different oils thickened with the cold, affecting delivery times.
Plus had a regression equation for that particular engine in the test cell.
Points of note is that the regression equations are on the crazy end, the cold pumping end, so their absolute use in the freezing and above range aren't there.
Note also, it's in whole poise, not Centipoise.
So take M1 0W40 and M1 5W30 at 0C (I'll just use Cst=Cp, it's close enough).
5.62P versus 6.33P - Delta = 0.71
Delta ROAT - 0.072*0.71 = 0.05sec
Delta 3bar - 0.062*0.71 = 0.04sec
Like I said, the formulae are around the actual measurable part of the curve...in the flat part, there's no difference with a PD pump.
For the cold end, note that J300 MRV (flow to the pickup is about 600P depending on grade), and that MRV halves with every 5C temperature increase roughly.
Originally Posted By: pbm
Shannow's graphs are a little over my head....Is it safe for me to assume that a 5w20 is not significantly different than a 0w20 at 0*F?....Let's use Mobil 1 as an example...How about Mobil 1 0w20 vs MS5K 5w20 (Mobil's dino) vs. M1 0w20 at 0*F?
Thanks...and sorry for my ignorance.
https://www.mobil.com/english-us/passenger-vehicle-lube/pds/glxxmobil-1-0w20
http://mobil.moovelub.com/sites/default/files/mobil_supertm_synthetic.pdf
MRV's, translated to "Poise", so you can follow them on the charts.
Code:
Temp M1 0W20 super 0W20 SUPER 5w20
-40C 92 268
-35C 45 (est) 130 (EST) 132 (EST)
-30C 22 (est) 65 (EST) 65 (est)
-25C 11 (est) 30 (est) 30 (EST)
-20c 5 (EST) 15 (EST) 15 (EST)
-15c 3 (est) 8 (est) 8 (est)
0F is -18C...not much difference between them.
at -40 (C or F), quite a bit.
Originally Posted By: Pelican
I can see how some oil may too thick when hot as in ...W30 vs ...W40 or 50; passages, clearances & tolerances may be too small to allow a thick oil through, but on cold starts the thinner the better IMO. Perhaps someone will explain. Thx
With a positive displacement pump doing the oil, it shifts the same volume of oil every revolution...
with oil in it's pumpable range, it takes the same time to fill the galleries, regardless of "W" rating, largely independent of viscosity.
Look at all the curves I posted above, that's the reason that they flatten out.
The above, for a given engine shows full oil pressure at 6 secs for SAE30 at 30F, 6 seconds for 10W30 at 9F, 6 secs for 5W20 at 12 F.
Put all of these oils at 60F, and they'll all take 6 seconds, because that's the time that it takes the pump to fill the engine.
Drop below the readilyy pumpable range, 10F for the 30, -9F for the 10W30, then the pumpability is starting to creep in.
If you are freezing and above, SAE30, or any of the W ratings will get there the same.
0F, vastly different issue, and you need to consider what you need to start.
