Any oil that meets the 5W qualification does so at -30C or -22F.
-5F would be no problem for any 5W oil without regard to basestock blend used.
You want the best flow at -5F?
You'll find that in a 0W, either M1 AFE or EP. QSUD is also pretty good with PP a tad thicker at the 0W end of things.
If I were really concerned about cold starts in below zero conditions, I'd run a 0W.
I used to use either GC or M1 AFE 0W-30 in our older Accords over the winter as well as in our '09 Forester, for all of which 5W-30 was the recommended grade.
Before that, I used lots of the pre AFE M1 0W-30 in our 3.0 Aerostar year round, with the Vulcan having 5W-30 as its recommended grade.
No harm in using a 0W qualified oil in any application.
