Also be aware that there are versions of the CR-V that are NOT AWD. They are front wheel drive only. Because the LX models are the lowest cost versions of the CR-V it is more likely to find a front wheel drive version in an LX because when new they are often sold to people who want the lowest cost version and the front wheel drive only is the lower cost version of the LX. So if you want AWD be sure to check that the vehicle has the AWD symbol on the back.
The AWD version is only AWD at low speed. Somewhere between 20 MPH and 30 MPH when accelerating it switches to only rear wheel drive.
If you use tire chains in the winter they are only to be put on the front tires even if it is an AWD. The correct chains are: Cable-type : SCC Radial Chains TC2111MM you can get them at NAPA for about $147.99 + tax If you get chains get an extra set of the rubber tension clips and use 2 sets to get the chains tight enough everywhere so they do not flap around.
