Originally Posted By: ZeeOSix
The V6 has lots of timing chains, and I read that dexos1 Gen2 formulated oils are supposed to be better for reducing timing chain wear too, so if true that's a good thing.
Wonder why your chains were so stretched - what oil were you using? How many miles were on it at that point?
I bought mine last year from the original owner, who was changing the oil at average 22K mile intervals. Toyota records show he brought it to the dealer at 96K miles with the check engine light on, P0016 error code...they quoted him a new engine. He continued running it and changing the oil at long intervals, until he couldn't get it to pass inspection and dumped it on craigslist for cheap.
I opened up the engine this Spring after running through Fall-Winter-Spring on Pennzoil High Mileage or QSUD at short change intervals to gently clean up the sludge, replaced all 3 chains and the guiderails, sprockets, and tensioners with Toyota parts.
Here's a pic of the new Toyota chain hanging alongside the factory chain, showing nearly 1/2 link of elongation at the midpoint:
And here's the factory #1 chain tensioner showing sludge rings that accumlated as the tensioner extended to take up the slack, one ratchet step at a time:
edit: and here's the computer MPG display on I-95 cruise set to 65mph and no AC, gas spiked with with TC-W3 at 640:1. I can not complain.
