Unless the cooler has air blowing over it by either forward motion or some type of fan it isn't going to do much.quote:
Originally posted by XS650:
Did you tell the guy about the advantages of an oil cooler?
what does that mean? what do they adjust?quote:
The true test will be tomorrow afternoon, as I'm getting it dyno tuned.
WOW 295F is hot!! Did the manual say anything about syn oil? I wouldn't think dino would last long at those temps. Did that VW come with a oil temp guage? Pretty cool to get one from the factory but wouldn't be better for the manufacturer to just put on a bigger oil cooler?quote:
The owners manual for my 1997 VW Passat VR6 I used to have said "normal oil temps" were up to 295* and not until then should you pull over and idle to allow cooling.
This is why I have decided to buy no more used cars! Get 'em new and know exactly what you have.quote:
Originally posted by Ugly3:
My Son-in-Law drives a leased SUV. He changes the oil every 20,000 miles or so and uses Meijer 5w30 (similar to Wally World $0.88 stuff). He turns the vehicle in at 40,000 miles and gets another one. Never has a problem!
Congrads PATMAN... glad to see you get the car I heard you talking about.quote:
Originally posted by Patman:
I don't know about other cars, but I've owned a 98 Corvette for a couple of weeks now -*-*quote:
What is wrong with running an engine with an oil temp of 270 degrees? Many engines run at 220+ degrees normally.
I was thorougly impressed today, because after doing 10 dyno pulls on my car this afternoon, the oil temp at the end of the day was still under 200F!! We did let the car cooldown before the beginning of the runs, then for over an hour in between the first and second run while I changed the plugs and put on a modified Z06 airbox. But even still, once we got things sorted out we ended up making 8 of the dyno pulls within an hour or so. And yet the oil never got super hot! Part of the reason could be because with the new cooling fan settings I've now got (which were a part of the dyno tune), now my coolant temp stays nicely below 200F most of the time. I'd probably have to get stuck in some seriously long traffic, or do some road racing, in order to see either the coolant or oil temps get super hot now.quote:
The other day I was driving along on the highway at 70mph for a while and the oil temp was 203. I put the hammer down and got up to 120mph and then let off, and it only climbed up to about 207. I'm sure if I drove at 100mph for a long period of time it might raise the oil temps, although then again my engine doesn't rev very high either (70mph equals 2000rpm)quote:
Originally posted by zoomzoom:
patman what was oil temp reading when going 100mph+ for a bit?
The true test will be tomorrow afternoon, as I'm getting it dyno tuned. So I'll probably be having 5 or 6 dyno pulls made, all within a short period of time. By the end of the last pull the oil will probably be good and hot! I bet it goes over 250 for sure.
Don't like to nit pick the mods, and it sounds like a great running car.quote:
The air fuel ratio is more stable now too, and is at 13:1. It was originally around 13.6:1 so it was a bit rich.
Max torque is often arround 12.5 and max HP around 13.1, these are rough estimates and every motor is different, and yes those ratios would be under load like WOT with the wheels on big steel rollers(dyno testing). O2s are all about informing the pcm so it can keep the AFR at 14.7 at light throttle cruise once warm.quote:
On the air-fuel ratio the first number is the air. 13.6:1 is a leaner mixture than 13:1. Both mixtures are relatively rich, and sound like the mixture applied under heavy load. At light throttle cruise the mixture is very close to 14.7 to 1. The richer full throttle mixtures help quell detonation and provide a degree of cooling.
Would be interesting to see UOAs on it at 5 10 15 and 20 thou. Meijer oil is packaged by Citgo. They recently had a rebate deal where you got up to 12 qts Meijer oil for 50 cents each. Would be good for an AutoRx regime. I have seen the Meijer oil in dino, high mileage, and I think also synthetic. Never bought any though.quote:
Sorry, the 13.6 was a typo on my part, it was 12.6 originally, so it was a tad richer.quote:
Yes he did.quote:
Originally posted by theguru:
Patman, didn't the dyno tuner have additional large fans in front of your vehicle during the dyno runs?
They reprogram the computer for more power. They adjust the air/fuel ratio to be better for power, and optimize the spark advance curve throughout the rpm range.quote:
do they reprogram the ecu? blueprint the injectors?
