Is yours a Japan Build or a North American build? They use different front rotors, but some brands have tried to consolidate by suggesting the Japan rotor on North American builds as well. The hat design is different.
I work on a lot of RX's. They tend to be quite hard on brakes as whole. The OE pads and rotors work fairly well, but the pads do not last long. I usually replace with OE from the dealer (the pink ones) because they stop well, are quiet and do not leave heavy pad deposits (like the Akebono proact's do). If you no longer have the factory shim kit, going OE may not be a cost effective option since the shim kits are expensive and are sold separately from the pads.
For rotors, the factory rotors or the Advics rotors from Rockauto or WP are a great choice. Akebono Rotors are ok as well if you have access to WP. The Centric Premiums are decent as well.
