Thinking of conventional for next oci
In the shop
I have become very money conscious or saving a ton. Sold most of stash and my old hi def tv. Considering going back to QSGB for 5k ocis. I know; i am nuts. Or, i can get Federated conventional oil for $1.49 quart thru work
Originally Posted By: rollinpete
The quaker state 5w30 hm looks real good on paper.
I used hundreds of gallons of QSGB way back. Dont think i need HM stuff
Originally Posted By: BrocLuno
Real oil is fine, no need for synthetics unless facing real freezing conditions or AZ heat in summer ...
100%
I just recently just ran "Everest" syn blend oil. Cheapest I could find. About $8 US for 5 liters. Ran it all winter and past what the OLM on my car said to go. Sent a sample to Blackstone, results were less wear metals than the average that Blackstone tracks. I can't see how you can go wrong with an oil that meets SAE SN specs unless you have some fancy turbo gizmo. QSGB will be fine.
Might be hard to do since it's getting really difficult to buy non-synthetic motor oils....
All of these conventional oils can go 10,000 miles in most applications now. Just check their specs.
$13.97 for 5 quarts of Quaker State, $22.65 for 5 quarts of Castrol Edge.
If each oil change uses an $8 filter:
5,000 mile OCI with QSAD, $.004394 per mile
7,500 mile OCI with Castrol Edge, $.004087 per mile
So, actually cheaper with synthetic.
I also switched to a blend after running synthetic for about 60k miles, due to a small leak at the oil pump.
I am now using QS-HM. Latest VOA looks good.
Originally Posted By: Marco620
Go Quaker State GB and PYB in winter.
Screw that. QSGB just as good as PYB
I can get PYB $13~ at Rural King. Never tried QSUD
Real oil is fine, no need for synthetics unless facing real freezing conditions of AZ heat in summer ...
LOL, or if you are like me with lots of WOT operations when pulling a heavy trailer
