Not another Valvoline R&P thread
I’ve had the 2007 Kia 3.8L MPI engine which was bullet proof and still didn’t burn a drop of oil at 270K miles of hard mixed driving . A family members 2017 Kia 3.3L DI engine is doing good to date at 70K miles .
We’ve had a 12 Sedona with the 3.5 in the family for 13 years and it’s been absolutely fantastic. About 151k now and plan is to run it to 200k before retiring.
I'd check out the filters subforum. Many have already plowed the path you're on. Premium Guard (e.g. Carquest Premium) filters are thought now to be the best. And we would by all means appreciate whatever you have to contribute as well. Cut filter photos are always appreciated.
At your suggestion I checked out Premium Guard Extended Life. The one thing holding me back was the bad efficiency specs posted on their web site. So I started looking at MicroGuard Select Extended Life, also made by PG, and cut apart samples of the PG4476EX and the MSL10322. They are both very nice and almost identical, but I noticed some subtle differences. One is place of origin: the PG was made in China, the MG in Vietnam.
Another difference is the filter media. The PG media seems to have a finer "grain", it's "smoother". The can is also a bit taller than the MG, so a bit more filtering surface area. The media thickness for PG .0360", for the MG it's .0363. This is measuring ten plies then dividing by ten
The gasket is also different, the MG has a rounded top, almost like an "O" ring. The PG is flat, both are red in color.
But then I saw your post about the web site being wrong after you contacted the company! I'll repeat your info here:
After calling PG tech support I finally got an answer!!
The micron rating range of the PG XL is 15-25. Meaning 98.7%@15 and 99.9%@25. The micron rating range of the regular PG is 42-60 98.7%@42 and 99.9%@60. The significance of 98.7% is an absolute micron rating for automotive oil filters.
These ranges are under the wrong filters on the website in error. I figured this out after the fact by looking up a regular PG and PG XL for one of my cars. At some point I will need to call back tech support to let them know.​
It makes intuitive sense that the finer-looking filter media would filter smaller particles, so that in conjunction with your efficiency report now has me on the PG side of the fence. They are both very clean, without any spattered glue like the Puro One, the pleats were straight, the ends crimped with a metal clamp, and the bypass valve was coil-spring backed and built into the bottom of the filter element, so no permanent bypass leaks! Both brands also came with a cellophane seal on the can, which suggests quality and an attention to detail not seen in many other brands, at least in my mind.
Bottom line: I'm going with the Premium Guard Extended Life.
I'll attach some photos showing the filtering media. The first shows the texture difference, PG on the right. The second shows how they look with a light behind, PG on the right. The third photo shows the gasket difference, this time PG is on the left.
Sorry, wrong attribution to the person calling PG. That was Glenda W. I'm new to this forum business.
https://bobistheoilguy.com/forums/members/glenda-w.103610
Thank you for cutting and sharing!
Love talking filters!
Yes, I’ve called PG several times now and the official PG EX(Extended Life) efficiency range is as follows. This also applies to the 10k filters made by PG for others.(Carquest Premium, Microgard Select etc.)
98.7%@15 microns(absolute)
99.5%@20 microns
99.9%@25 microns
The website has finally been updated for the EX showing 25 as the micron rating. The regular 5k filters are still incorrect and show the EX range like above(15-25).
PG has factories in Vietnam, China, and S. Korea. You will see some slight differences between factories but QC remains fantastic. Headquarters are in Memphis, TN, R&D and engineers are located in Bridgewater, MA.
This new PG filter just dropped late last week!! I’ll be making some calls today.
99.5%@20 microns
99.9%@25 microns
Are the efficiencies of the PG Extend Life and MG Select the same? As I mentioned, the filter media appears to be different. MG is slightly darker in color and appears to have a coarser (hairier) surface, but are both the same thickness. Intuition would suggest that PG is a bit more efficient, but who really knows? The MG can is also a bit thicker (0.025 vs 0.023) but I don't think that would make any difference. The P base gasket on the MG also looks great. I wonder if the P design is more resistant to leaking and blowout?
Both advertise 99%@25 microns and after talking with PG I believe they are. Not sure about the advantages/disadvantages of the P gasket. I’ve noticed depending on the model some have the P gasket, some don’t. I have also noticed sometimes the China made have a bit more glue vs Vietnam. Also the Subaru specific Carquest Premium is shorter vs the Microgard Select, I believe AAP opted for a one size fits all.
Nice. I’ll be wrapping up my first oci of VRP in my Northstar later this fall (Nov 1) which will have gone a total of about 6-7k miles including a round trip from Georgia-Maine (2500 miles highway cruising) so I’ll be interested to see that filter when I cut it open. Sump on the Northstar is 7.5 quarts so that works out in its favor.
Hello,
Which oil filters do you use with VRP?
I'll be coming up on my fifth interval with VRP.
I now have 5w30 VRP and Mobil1 EP oil filter for next run.
I wish so bad I could take off the valve covers and see if the engine is now silver after four intervals or is it golden colored?? Wish I had a scope camera to peek around.
Anyway, engine should be cleaner no doubt. Round 5 coming quickly.
I just bought a scope camera from Amazon for $60 which is not bad at all compared to the price of most. It even has the flex head.
Carquest Premium and O’Reilly Microgard Select are thought to be the among best filters out there now.
I am currently finishing up my stock of Mobil1 EP filters. Where will I find Carquest Premium filters? I've never seen an ORiellys here on the east coast where I am.
Thanks
Thanks
Order on-line? https://www.oreillyauto.com
I've also ordered a lot of filters from Amazon, including the Premium Guard Extended Life filters. I've ordered so many filters to cut apart that Amazon thinks I'm a business! I don't think I've received any counterfeit ones, yet...
Thanks
Advance Auto Parts. Ask at counter.
Or order online 15-20% off and pick up at local store in 30 min.
