901Memphis
Originally Posted By: turtlevette
Put a quart of Lucas trans fix in and see if that helps. The thickeners may raise the line pressure.
If you're getting that much black stuff on the stick another few suck and fills would help too. How is it going to hurt?
As mentioned a filter change might drastically improve the situation. Go to a friends house and do it.
You really don't want to put over 2k into this junker. How long before inspection fails it for rust?
No way I'd put Lucas in anything.
What inspection, I live in KY?
As far as putting money into it, I don't see many options. I can't afford a car payment and buying another 2k car just raises my car insurance and brings on another maintenance issue most likely. I don't see many cars for 2k that don't need anything.
Who are you to call the op's car a junker? It's cheaper to fix it than to spend multiple times MORE on a newer car. The P1811 code is pretty well known as is what causes it and what fixes it.
OP- I checked and the last Jasper 4T65E I sold had a list price of $2100.00. I knocked a bit off of that when I sold it.
So if I wanted to find someone to install Jasper what am I paying total cost? Is it $2100+install?
Originally Posted By: zzyzzx
Originally Posted By: 901Memphis
You did see the part where I've already done drain and fills right? It's had over 20 quarts of fresh fluid and code reset still comes back and still does similar stuff.
It usually shifts great when cold, then might slip very lightly when hot and after enough driving it bangs up shifts and downshifts.
Did you check the transmission oil pressure?
No I have not checked the line pressure.
