Originally Posted by painfx
Originally Posted by Donald
With respect to putting some of the Permatex purple on the metal to metal contact areas including the piston surfacr, the Permatex purple is not for rubber and if you put some on the piston surface that hits the pad you are likely to get some on piston boot.
I see that Eric O. From South Main Auto does that. I have also been thinking if it is a good idea to lube the piston to prevent rust?
I've even seen some Eric O videos where he slathers the purple stuff on the caliper pins as well, which I suppose would swell pin bushings and boots. People write in questioning him on this and he says he's never had a return or saw a problem from this. Then again, on some other brake jobs videos I've watched from him, he plucked the pins out and shoved them right back in w/out cleaning/re-lubing them with anything.
This is why I hate the thought of paying ~$400 for a shop to do a pair of pads and rotors. You never know how thorough of a job they're going to do.
