Yes those old Bugs I believe if I can remember back that far have a factory recommended OCI of 2000 miles.Does your bug have an actual oil filter on it, or just a screen you have to clean at oil change time?. My '66 bug had the screen "filter".,,
I guess you can buy city star or some other nd oil at a liquor store on the bad side of the tracks. But you won't normally find it at an auto parts store. Every sae 30 I run across has the latest api ratings. Such as this.I did some looking around and what I've found is, 30 wt oil could be used in a car, but they are mostly non-detergent. Most articles start off saying 30 wt, but start talking about 5 or 10w30 wts. Which pretty much all are detergent oil. Here's an example.,, https://findanyanswer.com/can-i-use-sae-30-instead-of-5w30-in-my-car
I belive that oil coking is caused by shutting off a hot engine that was worked hard without sufficient time given at idle for the turbo(s) to cool.Yes, I was meaning the function of the VII. Now there are 2 choices, one a grp3 with VII like 5W40, and a group II with no VII, SAE 30. Is the grp II SAE 30 just as coking resistant ?. Is the VII the main culprit for turbo passage coking ?
Indeed.I belive that oil coking is caused by shutting off a hot engine that was worked hard without sufficient time given at idle for the turbo(s) to cool.
A locomotive engine for example has an "auxillary turbo pump" that turns on when the engine stops for any reason. It pumps
engine oil through the turbo for about 10 minutes after shut down.
I ran straight 30 wt Havoline in a new 1993 Ford F-150 2wd, 300 six cylinder, 5 speed stick shift I bought for 12 yrs and 293,000 miles. In Southern Missouri. Was so far, the best truck I've ever owned.Hi BITOG users,
Anybody using straight 30wt in hotter climates n their passenger vehicles? - I'm talking the greater CA/AZ area where temps rarely dip into freezing temps. Would a vehicle which is spec'd for 5w-30 have any issues with this?
Thanks!
Longevity of those old 4.9L/300ci Fords isn't unheard of. Same can be said of the ol' slant-6 from Chrysler. The fact that you ran straight 30 grade probably had little to do with the success over any other reasonable multi-grade which likely could do the same. Those engines ran well on just about any lube, and considering the lower quality of lubes "back in the day", it was more a testament to the engine lube system design combined with a relatively low power-density (low stress) engine.I ran straight 30 wt Havoline in a new 1993 Ford F-150 2wd, 300 six cylinder, 5 speed stick shift I bought for 12 yrs and 293,000 miles. In Southern Missouri. Was so far, the best truck I've ever owned.
Sold it and the guy drove it for several yrs afterward.
I do agree with ya.Longevity of those old 4.9L/300ci Fords isn't unheard of. Same can be said of the ol' slant-6 from Chrysler. The fact that you ran straight 30 grade probably had little to do with the success over any other reasonable multi-grade which likely could do the same. Those engines ran well on just about any lube, and considering the lower quality of lubes "back in the day", it was more a testament to the engine lube system design combined with a relatively low power-density (low stress) engine.
