Ok, if you couldn't produce the list so be it. Bye.
I don't see why not, a modern SAE30 should be much better oil than what you'd have gotten 40 years ago should be made with group II base stock and even without a winter grade listed is probably close to 20W which makes it nicer to start on a cool day compared to some of that old solvent refined stuff that still had tons of wax in it, unless the engine in question has a flat tappet cam shaft and stiff springs then an HD oil with more ZDDP is probably better suited than modern PCMO SAE30.Is the modern SAE 30 ok to use with 80s turbo engines ?
Thanks, but I wasnt specific enough. Will it withstand the temps in the turbo journals and the supply pipes? Will it coke up compared to a grp 3 5w-40 ? That is my only concern.I don't see why not, a modern SAE30 should be much better oil than what you'd have gotten 40 years ago should be made with group II base stock and even without a winter grade listed is probably close to 20W which makes it nicer to start on a cool day compared to some of that old solvent refined stuff that still had tons of wax in it, unless the engine in question has a flat tappet cam shaft and stiff springs then an HD oil with more ZDDP is probably better suited than modern PCMO SAE30.
It's thick enough, and the very low VII's should help, but I don't think that is a great choice for a turbo with so many other better choices readily available. Our family blew up an 80's Audi turbo on PYB 10w40 many years ago, sustained boost under highway travel with high winds it wasn't enough.Is the modern SAE 30 ok to use with 80s turbo engines ?
How long did his cars last?? This aside, that is what I used in Havasu and still would today for summers there.Grandpa always used straight 30 and he lived to be 95.
That's really not a function of the grade. You're focusing on the wrong thing if you're looking for oxidation and coking resistance.Thanks, but I wasnt specific enough. Will it withstand the temps in the turbo journals and the supply pipes? Will it coke up compared to a grp 3 5w-40 ? That is my only concern.
