I did the opposite. Switched the riding lawn mower from conventional straight 30W oil to synthetic 5W-30 to make it easier to start off season for my joy rides to exercise the mower when the lawn doesn't need to be cut.
That really makes no sense if the oil meets the license or specification the engine requires and the climate is suitable for a straight-weight oil. After that it's a 30-grade just like your multigrade 0W-30 example. Anything above freezing and you'd not notice a difference nor would your engine.The only sane reason to do this is if you had a big stash. If I were that person, and was tight on funds, I'd do it. If I could afford it, I'd sub one quart of the 30 with 1 quart of 0W30 to help things out.
I would not do it because this one time at band camp... this guy ran it in his engine and it "didn't cause any problems"... that he noticed, in the time he ran it, before he sold it.
I was never in band.That really makes no sense if the oil meets the license or specification the engine requires and the climate is suitable for a straight-weight oil. After that it's a 30-grade just like your multigrade 0W-30 example. Anything above freezing and you'd not notice a difference nor would your engine.
Else what would make it insane per your statement?
I'm not sure how adviseable it is to mix straight grade oil with multi-grade oil, it causes a non predictable visosity since you have no clue how the VII in the multigrade oil will interact with the heavy base oil in the monograde. Since modern SAE 30 is around 20W it's probably pretty similar to the base oil used in 20W50 without the VII, so if you blend a bunch of 0w30 with straight 30, you'll have the mixing of the thin base oil from the 0w30 with the SAE30 base oil but also there's VIIs in the mix who knows that mix could possibly result in 10w40 or 15w40.The only sane reason to do this is if you had a big stash. If I were that person, and was tight on funds, I'd do it. If I could afford it, I'd sub one quart of the 30 with 1 quart of 0W30 to help things out.
PHX. Vegas. Los angela's etcOriginally Posted by ad244
Im still on the fence about weither or not I want to try a monograde 30w in the sump of my 3.4L Tacoma vs the 10w-30 I typically run vs a 0w-40 which seems pretty pointless when we're not seeing days below 80 degrees for 3 months.
What city are we discussing here? I want to move there immediately.
Yes, I was meaning the function of the VII. Now there are 2 choices, one a grp3 with VII like 5W40, and a group II with no VII, SAE 30. Is the grp II SAE 30 just as coking resistant ?. Is the VII the main culprit for turbo passage coking ?That's really not a function of the grade. You're focusing on the wrong thing if you're looking for oxidation and coking resistance.
Folks love to get into “W” ratings etc … but SAE30 and HDEO 10W30 etc … are visibly thicker at moderate temps and take harder tugs to start OPE … I like 5w30 in my walk behind mower and thicker stuff in the 19HP riderAll things equal a straight 30 is thicker between the parts than a multi grade oil.
I would go with a 10/40 first choice more so for 6 months of the year. If not then 10/30 year round.Hi BITOG users,
Anybody using straight 30wt in hotter climates n their passenger vehicles? - I'm talking the greater CA/AZ area where temps rarely dip into freezing temps. Would a vehicle which is spec'd for 5w-30 have any issues with this?
Thanks!
I think PYB and GTX still has pcmo mono grades. RP used to as well. SAE30 and SAE40.Arent 30 wt oils for ope non-detergent?. For that reason I don't think you'd want to use them in any vehicle nowadays.,,,
Nope.Arent 30 wt oils for ope non-detergent?. For that reason I don't think you'd want to use them in any vehicle nowadays.,,,
I did some looking around and what I've found is, 30 wt oil could be used in a car, but they are mostly non-detergent. Most articles start off saying 30 wt, but start talking about 5 or 10w30 wts. Which pretty much all are detergent oil. Here's an example.,, https://findanyanswer.com/can-i-use-sae-30-instead-of-5w30-in-my-carNope.
Does your bug have an actual oil filter on it, or just a screen you have to clean at oil change time?. My '66 bug had the screen "filter".,,I use 30 wt all the time in my VW Beetle. It fits the warm up curve for the air cooled perfectly. Parts of the motor expand at different rates and it keeps noise to a minimum when things are loose.
