Originally Posted By: motorguy222
I am using an ST filter now.The filter above looks good as far as construction but I am still not very happy with the way the ends are made.
Many put Fram down for the cardboard end caps when the elements of most filters are made of paper.If paper can take the oil why cant cardboard? I havent used a Fram in years but I used to use them most of the time and never had a known problem.We hear over and over that Fram is bad but is this more of a 'bashing' problem by some here or are there real reasons that they are bad.Some say that construction isnt the best for the price and that there is less element in Frams.Does less element really mean anything? Maybe,maybe not.It depends on what the element is made of.Fram uses a synthetic glass blend,this blend may be as good as another filter that uses more element but an element that is made of paper.
Some say that the seal between the cardboard and ADBV causes leaks there.Has this been proven on an engine that is running or are these just opinions based on taking a Fram apart? I am not saying that Fram is the best but are they really any worse than the others? If you consider the huge number of Frams that are used every year and the number of failures they have,is their number of failures any worse than that of others? Probably not.
I can't answer all your questions and you raise some very good points - but I can say that when I used the Fram oil filters on my 95 Ford w/ 4.0 V6 engine, I did have a problem with start up noise or rattle. It would start about 1,500 - 2,000 miles after I changed the oil. I started reading on the internet about the ADBV being poor on Fram filters.
I went out and bought a Motorcraft filter and put it on the vehicle (did not change the oil) and never had a problem with the noise again. That was several years ago and probably 75K miles or more! I've tried various other Purolator filters and never had a problem with the start up noise.
I really think SOME of the Fram bashing is unwarranted. But honestly for the quality of the base Fram filter, it SHOULD be a lot cheaper.
