Sluggish start when its 20 below zero.
Texas Hill Country
Well today we had a wind chill of 20 below zero, and I haven't started my truck in a couple days, so it sat until this morning sunday to go to the store.
Its a 98 f150, with a 4.6. Totally tuned up, running 0w30 german castrol for the winter. Truck runs fantastic. Battery is good everything is good.
When its that cold it won't start with the remote starter because the remote starter just cranks it for a second, then quits, then tries again five seconds later. So I have to physically go outside to start the truck which sucks.
Then I had to crank it for a long time before it would start.
So, I thought maybe I had a frozen gas line or water in the tank or something. The fuel filter is new also.
I decided to pick up a couple cans of b12 chemtool, and pour one can in the tank and see how it goes. I'll save the next can for next week. They seemed to be a good value for 2 dollars for a 16oz metal can.
Do you guys think that this is going to help out my sluggish cold starts?
Its weird, it will only struggle to start first thing in the morning. All the rest of the starts, it fires right up.
Thanks,
Justin
I always had hard starting from Castrol motor oil no matter if it was conventional or synthetic. Tried Havoline conventional and synthetic in winter with way better results. Done this the past two years on Havoline.
Originally posted by JustinH:
[QB] Well today we had a wind chill of 20 below zero
I read somewhere awhile ago that windchill temp. doesn't affect your vehicle. In other words if its 0 degrees but -25 with the windchill factor your vehicle only knows that its 0. It sounds to me like a battery problem.
Yes, pbm is correct. The wind chill has no effect on anything that is already at the ambient temperature.
FWIW, my '97 F150 4.6L has always been a bit sluggish when I try to start around 15F or below. I have run both dino and synth oils with similar results - the 0w rated oils may be a bit better, I currently have GC in my engine and haven't noticed much of a difference.
I am surprised that your remote start won't start the engine, but you can with the key. How long do you have to crank it before it starts?
I would also look at the battery and connections if it is turning over extremely slow. A good battery is a must this time of year. I have also found many good summer batteries to be bad this time of year. Cold weather is very tough on a battery that is at the end of it's life cycle.
Check this thread from last year - the effects of cold weather on car batteries are discussed.
web page
[ December 19, 2004, 10:03 PM: Message edited by: medic ]
I agree with pbm, what's the real temp out there, no windchill?
Maybe there's a dip switch on your remote starter you can use to adjust its sensitivity to not starting. Or you could do it manually when it's real cold (I know, defeats the purpose) or at least be where you can hear it trying.
Thanks,
Justin
Actually I have a same problem on my camry and someone said that fuel pressure regulator is bleeding off pressure back in tank. Guy said he has seen it hundread times. Since camry 99 has it right on the fuel pump I decided to not mess with it my self. I went to pepboys today and they said its not that its your starter. they tested it and proved their doubt. I was in hurry and didn't changed it today. Hopefully in couple of days I might give pepboys a shot.
Yeah, wind chill just affects how we feel in the cold conditions (due to evaporative cooling effect of temp and humidity and wind speed on our skin) cars only care about the real temp.
I had an electrical connector on top of my fuel tank for the fuel pump/level sensor assembly once that had a weak internal connection. Worked just fine as long as temps were decent, but when it got cold- no go. I started noticing there was no fuel pump sound in the mornings and no start-up, later in the day pump sound was kickin and truck would crank just fine. I finally jiggled the correct connector and found that I made it work. I had to unplug the connector and bend one of the internal contacts, and it has worked fine since then. Cold makes metal contract, so a loose connection could become a non-connection, as in my case.
Good battery and recent memory tune-up? Fuel pump working ok? All good questions this time of year.
Looking forward to the answer.
Rando
hmm, interesting. Plugs are new. Battery was load tested good.
Remeber, windchill is only a human application. Nothing else feels windchill other than humans.
-5f out and -15f with windchill, the temperture the truck is is -5f.
Your battery is not quite up to snuff if it is not starting like that.
Suggest charging it or replacing it.
Are you people craze going outside when its below freezing. Just kidding my antifreeze blooded brethren.
Batteries lose a lot of their starting power when cold.
battery. even though the machine says it's good, it can be bad. it's happened to me many a time.
quote:
When I was at school in Rexburg, ID, we had many, many days below 0 degrees F. One day, it was a sunny 28 degrees out, and I was walking around in jeans and a T-shirt, sweating! It was so warm, we pulled my friends couch out of his apartment onto the walkway in front, and enjoyed the warm weather (and the girls in shorts!). It was crazy!
Hello:
Not to high jack this thread, but Ive got some news.
Last night here in Northwestern Ontario the temp dipped down to -33C and -44 with the windchill. It was cold but still managed to make it out for some beers for my friends birthday
Anyhow I do not yet have my block heater installed on my truck (2000 5.2L) ram. So out I go this morning after the truck had been sitting overnight. I crank for 3 seconds, I think to myself it has enough juice, I crank for the second time and man did it make some scary sounds
no oil pressure registered for what I would guess 10 seconds
Now for the kicker, The oil is Esso xd-3 10w-30! an original battery and no block heater sitting in -33C weather for a day. I was happy that it started but I feel guilty for doing this, as I know better after having studied here. Needless to say the XD-3 0w-30 synth is going in tomorrow and the block heater next week. Those noises were enough to make anyone get off there *** and get some long overdue maintenance done. Anyhow for anyone who wants to know if a 10w-30 dino will start at -33C i guess the answer is yes
