Originally Posted By: mk378
Does it still have the fan shrouds? Does the fan size match the shrouds? Is the fan blade facing the right way? I don't know if it is possible on that model, but if you flip a fan blade front to back, it will still blow air the same way, but much less efficiently.
Yes to all of the above
Originally Posted By: Oil_Flunky
Cheap and easy first... clean out the radiator exterior with a garden hose. Put a bottle of lubegard cool it in the radiator, clean out the cooling system interior if dirty or neglected etc.
It's all flushed out clean with a new radiator.
Here's the link to another post I made
https://bobistheoilguy.com/forums/ubbthr...Hot#Post4452665
Originally Posted By: JimPghPA
Our 1985 Olds 88 has a 3 row radiator, but a 2 row is made. Is it possible that the radiator you put in your vehicle when it was replaced was a 2 row when it should have been a 3 row.
Radiator is stock, old one was 3 years old, standard O'Reillys radiator. Decided to replace it to see what would happen, didn't help. Replaced with a standard Parts Authority radiator through my mechanic's account, which is what any shop out there would use as a replacement radiator. His Jeep has one and my brothers has one, they don't run hot.
PS: Don't use more than 50% coolant in the mix, maybe cut back to 40 or lower in AZ.
Antifreeze is at 40% and distilled water is at 60%
1) Air is heated up by the AC condenser before it enters the radiator so the radiator is hotter when the AC is running.
2) If the temperature of a comparable vehicle is normally 195 with the AC on and your identical vehicle is 230, you probably have a clogged cooling system. Flushing may clean out the engines cooling system, but usually once a radiator is clogged internally you have to replace the radiator.
You say all the cooling system has been replaced, but how old is the radiator? If it is 10 years old or older it could be that the radiator is clogged up inside.
Radiator is 1 month old
