Originally Posted By: dlundblad
Originally Posted By: zorobabel
Could you please link the dial indicator?
Originally Posted By: The Critic
NAPA premium is their economy line. Napa Ultra Premium are the ones you want. Affinia makes most of NAPA's brake line and they also have a coated economy rotor option (FZN rotors) as well.
FCA specifies a maximum of .002" lateral runout for the front and rear rotors when installed. I find that many economy rotors are not able to achieve this spec due to the quality of the machining. With the premium rotors you are usually able to achieve this without issues.
I encourage you to buy a dial indicator from HF and measure the lateral runout of the installed rotors. Excessive runout will cause premature vibration to develop.
A HF indicator could easily be that .002 off.
Also, your measurements are only going to be as good as the way you're holding the parts.
Accuracy of instruments is a fair concern. I have compared multiple HF dial indicators to other brands and have not found any meaningful differences in their accuracy, so I feel comfortable recommending them for this purpose.
